trying to make a purchase but items will not add to cart. should i phone Cafe Press?
Just tested in IE8 and Firefox. Firefox works fine, but IE8 is intermittent when adding to cart. Changed teh settings a bit, please try it again, and also try this url: QuadCRAZY Online Store
    • By geezer99
      Well, I bought the Axis 500 sold at Lowes for $8999 a couple days ago.  This post will be about my impressions as I use, fix, and abuse the machine.  I will add to the post as I gain experience with it.
      Thanks to other posters on this site warning of new machines with loose hardware, one of my first actions was to crawl all over it checking fluids and connections.  Zirks were all freshly greased, fluids in engine, and gear boxes were up to level.  One of the little gas struts that help lift the bed to dump was dangling with only one end connected, and the other strut had not been fully tightened.
      The rear gearbox does not have a differential in it.  It is essentially a solid axle.  Tight turns on lawn will leave tracks, and turns are not as tight on pavement.  In my case this won't matter much, but if you plan to use it on a lawn, this will create tracks on turns.
      To check engine oil you need to remove both front seats and a plastic cover.  This according to the manual.  I'm pretty sure it can be checked with that stuff in place, either from under or above, but that remains to be seen.
      I am not used to a CVT transmission.  I am used to a clutch and multiple gears.  This one requires giving it plenty of gas out of the hole and then backing off to get it to shift up.  I'm sure I will get used to it, but I'd like to be able to take off quietly if I want to.
      The doors have bungie cords to act as springs to close them.  I removed the driver door so I would not need to fight the constant pressure to close.  Problem solved.  I will leave the passenger door as is.  Gotta keep the grandkids safe.
      Here is some stuff I like:
      I was concerned about there being enough torque to slowly climb a steep hill.  There is.  I will elaborate more on this when I've had it on my steeper trails.
      The display has dedicated lights to indicate status of gear position, low oil pressure, over temp, and a bunch of other stuff.  This helps a beginner with feedback that an action taken was successful.
      The sparsity of knobs on the tires dig in well on most surfaces.  I bet they wear out fast on pavement.
      The tilt bed has a tail gate that is easy to operate.  Much like early Japan pickups.
      Steering is responsive and little slack.  Remains to be seen how long to get loose since the u-joints are operating at quite sharp angles.
      Seats are pretty nice.  Will be interesting to see how long it will take me to poke a screw driver though them.
      Seat belts are included to hold grand kids in.  Won't go over 5 mph if both aren't buckled.  Yeah, it works to buckle them empty.  Doing this leaves the belt high on back, so you don't have to sit on it.
      Hauling it home, my trailer wheel wells were too close together to clear the tires of the UTV.  This required driving it off center a bit, with one set of tires inside the wells and one side driving over the wheel well.  Creeping over the one well required climbing a 10 inch vertical well.  The ability to lock the front axle differential kept both front wheels pulling as I drove the one side up and over the wheel well.  The guys at Lowes were impressed.  They won't touch any but an unobstructed flat trailer loading.
      tom
    • By exalrod
      Hello All !
      I am looking for a service manual and wiring diagram for a 2005 50cc Polaris Predator 4 wheeler.
      Could anyone help with this?
    • By p5200
      Hello, would this be a good Master Link tool for pressing master link plate back on? I've seen others made of aluminum but thought this one might hold up better. Thanks! 🙂
      https://www.amazon.com/BARTOO-Motorcycle-Convenient-pressing-Alignment/dp/B0C4FB1V7D/ref=sr_1_3?crid=1KRW04WLD82EI&dib=eyJ2IjoiMSJ9.4Y2_vOEctIVv0vgmajSYXL844RphCjGBrMsiewv7Z1sVIMYMM5OQNBL0cXeHLmUDsnKMO5JffQPEP8vl4xuxCUczEfKGgw4r-MYmLgCzydGm9sHnK8hX7o1AqXunVpgpR8RrfQ8noUmfLyoxTqUcrl9tj82jDWeB5CL1rifd--ufsiyaWkBl4omd_1qyx7a97BvOTogpK40NTm9BfKjSt2H5mXrjEnhEOcxSYxUHiRx61KbfDBaA8B9CvwQjM3qGIf4Ay1zWxxPURTnX5qjhddcAADez5JNCFVrUYeLE-7M.sFaeyu09Q7O8v9B0NPjaDYDuHqVqE4uyxspDEpxBs6U&dib_tag=se&keywords=chain+press+tool+for+polaris+500+scrambler&qid=1709916341&refinements=p_85%3A2470955011&rnid=2470954011&rps=1&sprefix=chain+press+tool+for+polaris+500+scrambler%2Caps%2C198&sr=8-3
    • By p5200
      I have a 1987 Suzuki dual range 230 and a 96 bayou 220. I'm trying to figure what oil to use. I normally put Amzoil synthetic in most everything. But I understand there are concerns over the wet clutch. I've heard rotella 10w40 full synthetic,5w40 synthetic,10w30&40 non synthetic. I do live in Michigan, so temps cold and hot are encountered. It could be below zero or 90 degrees farenhight. I don't have manuals for them. Any help is greatly appreciated!
