Hey Fellers & Ladies,
To day i installed my kik azz Barkers duals for my rappy 700. Everything went fine, except for one thing. On the left side, right where the header and muffller pipe connect, the pipe touches a group of wires
I tried a piece of asbestos like/rubber gasket material for a heat shield. But it still didnt do the trick.
Has anyone had this problem??
Any suggestions to fix this problem??
* in the pics, i still have the gasket installed
u could try to loosen up the exhaust and pry the exhaust up with a bar,that may give u a little room,and then wrap the wires with an exhaust wrap,and tighten the exhaust while u have the pry bar in there...just a thought....
Doesn't seem right that the pipe runs so close to those wires. I'm thinking there may be a bad bend in the pipe somewhere causing the tight fit, or something was put on incorrectly. I would call the manufacturer or retailer that sold you the pipe and see what they have to say, they may need to send out a new part for you.
Anytime yyou are hooking up an exhaust system, you want to weight to tighten everything after you get the pipe lined up. It will never fit right if you tighten up the brackets as you are making your way back.
    • By BillR94
      Thank you for your time
      Bill
    • Guest Fox300exchic
      By Guest Fox300exchic
      Here's mine...
    • By wjmedic
      Recently rebuilt front end on this Polaris 400. New axles, bearings, seals, control arm bushings, Hilliard clutch thoroughly cleaned and inspected with no damage noted.
      Everything put back to together. Placed bike on jack stands all four wheels off the ground, started in 2 WD switched to AWD both front tires spinning, when AWD turned
      off right front wheel will not disengage from AWD. Checked voltage at connectors both left and right connectors have no voltage with AWD switch off, and both have 12.4V
      when AWD switch is turned on. Repeated turning switch on and off several times with no change in condition. I am thinking this must be something mechanical with the
      Hilliard clutch on the right hub ie. weak spring or stuck rollers on the Hilliard clutch assembly (Is this a logical thought?) any ideas on trouble shooting this before I disassemble the
      right front hub again
    • By sunn
      Has anyone had experience with the installation of the Optional RH Side Panel Close Off Kit as shown as p/n 2207445 which is supposed to help control the heat on the right side on my legs?  Right now that panel is wide open with excess heat on my leg.
    • By heath
