I have a 2000 ds 650. Sometimes it will start sometimes it wont. when it does start it will only run for about 10 seconds and then it dies just like you hit the kill switch. Even if you hold the throttle at a higher rpm it sounds great till it dies. im sure it has to be electrical can anybody give me some feedback
Get a repair manual and start testing ignition components, my best guess would be that you have a bad CDI box, but it could be alot of different things so you would be best off testing everything and checking for bad connections before you start buying parts. Good luck, these types of problems can be tough.
thanks josh. I got a shop manual im gonna start going thru all the tests with a voltmeter. it is definatly electrical. It wouldnt even start tonight so I pulled the plugs and it would only spark one time when i hit the start button. Thanks for the feedback. I just wish they didnt make stuff so complicated. Whatever happened to the good ole days when it wouldnt start youd either pull it or coast start it and you was good to go.
Check your battery, They have to have a good strong one to run. Don't over charge it no more than 2anp. If it's not that then it could be the voltage reg. Check voltage at the battery. If it's over 14+ it could be over charging.
  • 7 years later...
