Sign in to follow this
Guest Fox300exchic
Mud Tire Buyers Guide
Guest Fox300exchic
This is for all the mud mashers, the muck hunters, and the slop soldiers. We know you spend your weekends in a pit, churning up the thickest, nastiest, gnarliest mud you can find. For this, we salute you. For this, we have also put together a collection of some great mud tires. Read up, mud maniacs, and find the tires that are willing, ready, and able to go into battle with all the mud you can find.
http://www.quadmagazine.com/quad/newgear/article/0,24942,1227626,00.html
Share this post
Link to post
  • Similar Topics
    • By Rich1028
      Gladwin Trails Not What you Expect to Find on A Quad Trail
    • By tatjeff
      can anyone help me figure out year and on my grizzly i have no clue rode many of them very first ever owned
    • By Dan Tressler
      I have a 2018 Sportsman 570 SP Hunters Edition. I bought the quad new in August of 2018 and put around 20 miles on it with no issues. In early January of this year the quad was acting as if it had a bad battery even though it had been plugged into a tender. I checked the battery and it tested well so I took it to the dealership for warranty service. They had it for almost a month. They determined the quad had a bad EPS unit and swapped it out. Then they told me that the wire for the EPS needed to be updated as they could not program the new unit with the old wire. After the wire came in dealership told me they were still having troubles programming. After another week and a half they told me that they had consulted several times with engineers from Polaris and found a workaround and that the quad was ready for pickup. I contacted Polaris to inquire about the warranty being extended as it was in the shop for a month. They extended the 6 month factory warranty for an additional 3 months. I picked the quad up and the dealership said that the 2018 SP editions were known to have issue a with the EPS units but believed that they had fixed mine. I had it back for around a month and took it out a couple times for short rides and everything seemed fine. I parked it again for a few days and when I went to start it same issues (acting like the battery is no good and won’t start, when I jump start no power steering). Took it back to dealership and waiting to hear what the diagnosis is this time as well as their plan to fix this permanently. Just wondering if anyone else has had issues similar to mine or can give me some advice. Thanks in advance!
    • By Seymore
      I made my intro about a QuadRunner I was working on and found a multitude of problems. Most I fixed, but I'm thinking that I'll be making more trips to see the 90' LT-250/4WD. Age and needing regular attention is the reason. The owner, NOT being mechanically inclined, adds into the equation.
      So, I deliver it and was offered, as payment, a 95' LT-250/4WD, with paper. It didn't run and had been sitting outside for last 12+ months. It was (basically) all there. This happened Saturday and this "Barn Find" came home to live out it's final years (I suspect).
      Today I finally found time to look at her. Not a pretty sight. Rough life, many hrs....... MANY! Only 2399mi, but the speedo is disco'd. I just want to know if this will be worth pursuing. First things first, a really good cleaning. I hate working on dirty vehicles.
      The battery actually took and held a charge! The carb was pulled, cleaned and the tank drained. Found a broken orange wire, dangling loose, near the carb. It was hot when the key was on and ended up connecting to a 10A fuse block. Well, I wonder why it didn't run???? Hmmmmmmmmmmmmm!
      Carb back on, fresh non-eth fuel, had to remove the air filter for this test (needs replacement), sprayed a little ether..... hit the starter, fired and died. Third time's a charm, she runs. I'll be going thru things as I can and questions will follow, in this thread.
      WOOHOO!!!
    • By artis allen
      I bought a Kazuma Cougar 250 from a guy who used to fix ATV's but wanted to get rid of all his machines because he's "too old" and wants to quit fixing them, from what he says.  anyway,  One of the machines I bought was this Kazuma which I can't find any parts for it, or very little parts.  I found one website that still sells parts, which I'm thankful.  For the internal parts, I had to refer to the Honda Rebel 250 for parts.  I had to buy 2 new pistons and gasket set and I couldnt find the parts so I did some research and found that alot of the parts are similiar so I ordered it and it was a match.  I also used the manual for the Honda Rebel/Nighthawk and use this information to disassemble and assemble the motor.  Very helpful for anyone who has one of these things.  If anyone has more info on these things, please feel free to post.
  • Similar Tagged Content
