I just recently purchased a Polaris xpress 300 and have had a number of problems.. I purchased it in none running condition and found that it needed a top end done.. after completing the top end and not being able to find the oil drain plug for the engine, any kind of dip stick to check the oil, or any where that I could fill the engine with oil I was already frustated enough.. and then when i finally did get it started and tried to put it in gear and it would just grind(no matter what gear) My frustation has become monumental.. any help with this problem would be greatly appreciated.. i've already tried to idle the engine down to it nearly stauling out and then tried putting it in gear and it would just grind, or if i tried to force it it would just staul out completely.. for fear of tearing up gears I would like some input procede any further..
Thomas,
i have had several of the polaris quads and have had problems with them ... you should check to see if the belt is to tight and also if it isint then check to see if the clutch is grabbing and or draging ... if the rear pully on the belt system is turning while in idle then it will grind when trying to put it in gear ...
The transmission problem sounds like the silent chain inside the trans its something I have repaired on several its not hard but the trans has to be removed and cost about 60.00 to replace. Ajusting the rod might get you forward or reverse but not both.
I bought one last week with the same problem........ Polarisatvrepair.com Todd
  • 10 years later...
      Topics covered include:
      Polaris RZR 570 engine repair
      Brake system repair
      Popular related searches:
      Polaris RZR 570 repair manual
      RZR 570 wiring diagram
      Polaris RZR torque specs
      RZR 570 clutch problems
      Polaris 110 EFI engine repair
      Brake system repair
      Polaris ATV torque specs
      AWD and differential repair
      Brake system service
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
