Similar Topics
By Valkman
Hey all, new to the forum. I just bought a 2001 King Quad, and the clutch is slipping. I adjusted the play with no improvement, so before I go through the trouble of replacing the clutch disc, I want to see if motor oil in it is the problem. My question is Rotella T4 ok to use? I run in my motorcycles with no issues but I thought I'd get your input.
By Fiend_138
Just picked up a 2014(?) Chinese quad for my kids to play around on. I can get the quad to start up, but then it dies out when we get ready to take off. Do I just keep playing with the carb, or is there something else I should be looking at?
Also, what kind of amps should I be looking for in a replacement battery?
By Am2007
Hi everyone,
owner manual
service manual
engine manual
By Malaka
Need new tires for mostly plowing and running around. Found some good tires.
specs call for front 26-8-12 Rear 26-11-12
Has anyone put 27-9-12 & 27-11-12 as more of selections going up on front and taller
thanks all
By ridindirt1965
Replaced clutch bearings........ either not getting enough rpm's or the belt is slipping any known information would be appreicated 2004 90 sportsman...............
Similar Tagged Content
- 8 replies
- 6,146 views
- 0 comments
- 1,791 views
- 3 comments
- 4,445 views
- 7 comments
- 4,508 views
- 7 comments
- 2,813 views
Gallery Images
1
4
5
2
3
3
3
4By mannyortiz7,
1
5
4By trxridr,
1
1By Llanier5,
0
6By BlueBowtie,
0
4By crazt4stroke,
0
7
1
