My 2001 660 raptor seems to be having some issues with the rear axle nut. Seems like about every 2 rides the rear axle nuts back off and loosen up.I average about 75 to 100 miles a ride and this is driving me insane. The rear bearings and seals have been replaced and the axle has been upgraded to an 2003 axle because i had a mishap with a tree,kind of jumped in my way...lol So i got pissed off and ordered a mod quad double locker after market axle nut to hopefully cure this issue. I would love to hear any input you guys and gals my have. Is anyone else ever run into this issue,and how did you fix it? ,Thanks a bunch
:realmad::aargh::mad:
that part of me is working awesome.....thank you very much...lol
Sorry to hear your having problems with your nuts :laugh:All I can say is tighten it more I did my bearings on my Honda and the same problem accured Finally we just got out a big wrench and a cheater bar and it worked !!!!
Put an aftermarket axle on and you have to tighten the axle nuts about every moto. The only cure for it is an expensive aftermarket locking nut like what you ordered.
Keep in mind that everytime you crank on the axle nut that you are putting force on the axle bearing. That will eventually lead to premature bearing wear.
  • 10 months later...
buy a nut with a locking grub screw, the nut should only be done up tight enough to take the play out of the axle and then locked off with the grob screw otherwise as has been said before it will lead to prem bearing wear
    • By HeWasRidinDirty
      I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
    • By jeffrocdx
    • By LCP92
    • By Gtc4d
      Thanks.
      Todd
    • By jordan_ATV
