Tread Lightly!'s "Respected Access" Campaign - PSAs
By oztrax
MAX 4 6X6 2008
By HeWasRidinDirty
I rebuilt the carb on said machine. When I hook up the auxiliary gas tank it runs fine and everything is cool. When I put the fuel tank on and hooked up the lines, it completely flooded the cylinder and even about an inch of fuel in the air box. I'm pretty sure that it comes from the little hose on the petcock and hooks to the top of the carb. WTH is that even for? I mean the thing runs fine on the auxiliary tank, so idk And on the petcock when it's in the "on" position, I get no fuel. The petcock from the bike I took it apart and checked out how it operates. The sharpie marks indicate how it really works. Now the other petcock w/o the sharpie marks is an old one that was leaking that I removed from a Polaris quad. It's exactly the same thing, except the small hose and nipple have been removed. I'm so confused, LOL
By jeffrocdx
By jen
Cannot find out why 12 vdc 4 (4) commutator starter motor has no power. It will run full speed without load. But with any load will not turn. Repaired broken brush holder and insulated an internal wire to magnet that was bare and rubbing. cleaned commutator segments. Ohm readings while slowly rotating commutator was 1 ohm. When attempting to run with load it will not turn and Bat vdc only pulls down to12vdc. Cannot find an internal wiring schematic. I can buy a rebuild kit ~$35 but WTH?
By alexwv1863
I'm currently working on an 04 Suzuki Eiger 400 and ran into some issues. Main issue being it's really hard to start. Once I get it started, it runs bad. Sounds like it's missing, which I'm pretty sure is an idle issue. It's not my 4 wheeler. I'm working on it for a buddy. Someone started working on the original carb and 2 jets were missing when I got it to work on.
So, I ordered a new carb. To get it to run, I had to adjust the throttle screw on the handle bar almost all of the way out. Even doing that, it still sounds like it's bogging down and missing.
I did put a gas filter on it, which I'm questioning whether or not that's the issue and it's not getting enough gas like it should. The petcock only has an On, Reserve, and Prime option. It also has 2 ports. I guess I have the hoses hooked up right. There's no way to shut the gas off completely, and also it looks like there's no gas getting thru unless I run it on Prime. Reserve drips gas. I'm going to take it apart today and clean it. I'm also going to take the jets I need out of the new carb and put in the old one.
I don't know what all this person did you the 4 wheeler before I got it. There's odds and ends missing that I've noticed so far. What else can I try or look for? What could be the gas issue with the carb and petcock? The carb was completely off the bike except hanging onto the throttle cable. The diagram I found for the carb doesn't help me with hose placements. Any help, or questions would be appreciated. I can attach photos if it would be of help.
