Damm Bimmerdog !! Is that for the drunk dog ? so incase he falls down and hit his head !!!!:laugh:
I guess I can`t talk I bought a pair of Fox Floats shocks for my 450R :yes: Wife walked past them half a dozen times and said nothing !! YET :laugh:
my wife gave up saying anything every time I do some thing new to my quad...she just says "you better do the same to mine"
My wife has no interest in riding !!!:laugh: Just shopping :laugh:She lets me ride when i want to !!
my wife bought me a set of works tripple rate shocks with rezzies for my 400ex a couple years ago 4 my birthday ... lol.. but thats the only thing ive ever got quad related from her ... the bad thing is i dont have that quad any more .. but have the shocks in the original box in the garage... only used them for a few races ...lol..
I have a 400ex blink blink blink
    • By middlebrookgt
    • By jannonballs
      What is this tube for?
    • By Doublewidekings
      I am looking for what you would consider the best ATV winch for under $125.  Thanks in advance.
    • By Cobra_kai83
      The gas in the tank was bad so I drained it and put new fuel in. It still wouldn't run so I took the carb out and cleaned it. Re-installed the carb and now it will only start and run under full throttle. It also runs rough like this. The engine stops running once I back out to 1/4 throttle. What the heck is going on?
    • By remnar
      New member here,
      I have searched here and other places and have not found an answer to my problem.   As the title says I have a 2014 420 Rancher that recently started having an issue were the revs before the clutch engages.
      I have checked the oil level (per the service manual) and replace the Valvoline ATV 10w40(less than 5 hours) with 10W30 GN4 for good measure. I have used the "pin" method to pull a DTC.  I shows a 8-1 which is a TPS error.  This makes some sense, as if the computer doesn't read throttle position correctly, it could have this symptom. I have checked the source voltage, and tested the TPS off the quad with a Fluke and a power supply at 5v.  It is smooth and does not seem to be a bad sensor. I am confused by the DTC, because the PS light blinks the code, not the check engine light.  However, there are no PS codes of that value.   This condition appeared after a couple days of driving in the cold (~32°) and driving though some water/bogs.
      A couple questions.  First has anyone seen this issue, and do you have any suggestions? I have followed the troubleshoot right up to the point of replacing the ECU, which I don't seem to have one on the shelf :)
      Second, anyone used a OBDII reader with an a 4pin adapter to pull codes?  If so, what system do you use?
      Beyond the rev issue, the quad runs and starts perfectly and when it decides, the clutch grabs tight (no slipping)
