When did it start ? (pulling to the left ):yes:
wen i get on other forwheelers the handling feels wierd cause im used to mine pullin to the left..... if u hold the handlebars completely straight it starts driving off to the left side of the road:skeptic:
Ok so if it pulls while doing wheelies you eliminate the front end. Mine would always pull to the left because of a slightly bent axle. How it did i have no idea. But i pressed it straight and made it round again. No more pull.
Now your case could be:
Rear tire pressure
Out of round tire (over inflated once by accident)
Axle or carrier bearings siezing
Frame damage
Rear tire pressure
Frame damage
ok is it possible tht the pulllin to the left could be connected with the sounds the rear is makin like the bearings perhaps?
Quite possible. I would remove the rear axle and have a peek at the bearings. If one makes any noise while you spin em replace both
If one bearing is shot it might be causing a drag on the chain. Have you noticed any power loss?
There could be alot of factors but its best to eliminate what is not causing the problem first if your not sure.
no i havent realy noticed a loss of power just real loud grinding noise
Just out of curiosity does it pull to the left when you get a wheelie going?
it may vere do to the chain being on the let side low tire pressure bearing carrier being out the way you are setting on the seat. tread tire wear differnt size tires in height and in wideth
    • By harryjr
    • By Trent Finnessey
    • By Dumass
    • By DanOnWD40
      Hi guys, so Im i cam across this pretty nice quad. Its a 2003 400ex. Its priced at a little over $1,000. The seller states that it was previously rebuilt and has a hot cam in it. However, it is not firing. He says that it turns over and has spark. He also redid the wiring harness and still couldnt get it to run. I have some experience with quads from previously owning one.
      My thoughts are its either something witht he wiring harness(cdi, kill switch...) or it isnt getting the right amount of fuel(needs carb rebuilt) or it's the valves. Or could it be timing? What do you guys think? Let me know!
      400EXTurningOver.mp4
      I have attached a video so you guys can see how it sounds like. I feel like it wants to start but is missing something...
