Anyone ever deal with balistics batteries? They look like the ticket for me
I also use a schumacker trickle charger
Wow now thats a cool battery
8 Cell EVO 2
Dimensions: 112MM (L) x 60MM (W) x 103MM (H)
Positive Terminal Location: Left
Weight: 825 grams (1.81 lb)
Voltage (Charged): 13.6V
Amperage: 15 Pbeq A/H
Cold Cranking Amps: 275 CCA
Operating Environment: -18°C (0°F) to 60°C (140°F)
Typical Applications: 1000cc and under multi-cylinder motorcycles and 450cc singles.
8 Cell EVO2 (100-011) - $159.99
I been doing some research and I haven't been able to find too many reviews on using this battery on ATV's and Winching.
I swear by the Odyssey batteries.
I had one in a old standup jetski that lasted a good 10 years under unspeakable abuse. Full discharges, floodings, and full salt water shorts.
They also have near no internal discharge do they can be left alone without a battery maintainer for seasons on end and will still be ready to go when needed.
They are expensive, but so worth it.
8 Cell EVO 2
They might be a newe company but the specs on the batteries are awesome. an 8 cell battery weighs only 2lbs!
I hope this isn't considering a hijack of the thread.....
But someone mentioned using a trickle charge on the battery...
Is the necessary?
What qualifies for if it is necessary? The length between rides and/or the temperatures in the area?
Sent from my DROID X2 using Tapatalk
It all depends on the temperatures and parasitic draw. It's best to remove the battery and store it somewhere where it will be warm. Also lead acid batteries (wet cell) have internal draw that happens all the time, so they will discharge themselves and it gets worse with age.
It's a good idea to put them in the garage and on a tender every so often during winter. This also keeps the electronics in your quad from draining them. At the very least, disconnect the negitive terminal before leaving it be for long periods of time then charge it before you use it again.
      Topics covered include:
      AWD and differential repair
      Brake system service
      Popular related searches:
      Sportsman 570 wiring diagram
      Sportsman 1000 wiring diagram
      View File 2020-2026 Polaris Sportsman XP 1000 S service manual
      Download the 2020-2026 Polaris Sportsman XP 1000 S service manual PDF for complete factory repair, maintenance, troubleshooting, and diagnostic procedures. This comprehensive Polaris Sportsman XP 1000 S repair manual covers all major systems including engine service, EFI fuel injection, clutch and transmission repair, AWD drivetrain systems, suspension, steering, brakes, electrical troubleshooting, wiring diagrams, torque specifications, and factory maintenance schedules.
      Designed for ATV owners, mechanics, mud riders, trail riders, and DIY enthusiasts, this factory-style service manual provides detailed step-by-step instructions and diagrams for maintaining, repairing, and rebuilding the Polaris Sportsman XP 1000 S high-performance utility sport ATV.
      Polaris Sportsman XP 1000 S engine repair
      AWD and differential service
      Suspension and steering repair
      Brake system maintenance
      Oil change procedures and maintenance schedules
      2020 Polaris Sportsman XP 1000 S service manual PDF
      Sportsman XP 1000 S wiring diagram
      Sportsman XP 1000 S maintenance schedule
      This Polaris factory repair manual is ideal for riders looking to maintain, troubleshoot, repair, or upgrade their Sportsman XP 1000 S for trail riding, mud riding, hunting, utility work, and extreme off-road performance.
      View File 2025-2026 Sportsman 6x6 570 service manual
      Fix your ATV with the 2025-2026 Sportsman 6x6 570 service manual. Features factory torque specs, troubleshooting steps, and maintenance charts. 2025-2026 Polaris Sportsman 6x6 570 Factory service manual. Complete repair, maintenance, and wiring guide for your 6x6 ATV. Download your copy today!
