Today I started some basic maintainance on my AC... This is where I ended up before the cold and dark got to me...
Oil changed, and I started digging for access to replace the air filter box.
How far do you go for your seasonal maintainance?
oil change/ filter, clean airbox and filter, rear end fluid, tire pressures. Grease obvious joints and plow mounts. Other than that my machine seems to be a happy camper. ( Now that I said that something will break.)
The plastics get pulled and the bikes are gone thru every year. Most times I have a project in mind anyways like different clutching or performance mods. I always change my oil in the spring even if I do the overhaul before the winter.
Edited by swampcat07
Why are you replacing the air box? Are you going with the new setup?
No.. Back when I rolled it years ago the box broke off the crankcase breather hose fitting. I had glued it back on and kept the original box. I noticed a bit ago that it had broken free again so I just ordered a new box and filter to replace it.
I'm keeping the quad stock. It works really well as is. It even still has the stock front air intake setup. Perhaps I'll consider a snorkel setup next year if I find it necessary.
  • 9 months later...
Oil change after every third ride or about 10-12 hours. Air filter gets cleaned and reoiled with the oil change. After a wash i remove plastics for a quick check of nuts amd bolts etc. Tire pressure, chain tension, and axle nut gets checked before every ride. Brake and clutch play are noted during a ride and adjusted accordingly
Sent from my SGH-T989 using Xparent Blue Tapatalk 2
^ That gets a little pricey after a while though no? How many hours do you ride for at a time?
It depends !! we ride sand dunes and trails Not to pricey I get Rotella and Wall Mart for $15 a gallon :yes:Its 4.5 oil changes for me !!:yes:
Edited by quadnut20
for maintenance, I go to my garage. I have been working on ATVs since I was a kid, with my father. Now I own/operate SRP Machine in South Mills, NC. I have clients who drive all the way down from NY to have me rebuild their engines, and have had motors shipped from Canada for porting. For quality maintenance, there is no distance too great. The key is to find an honest, experienced technician. If anybody is looking for one, please visit me at MX Performance Parts | SRP Machine | Call 252-771-0019.
I know with my Honda 400ex the engine oil also is used for the transmission and clutches. I now run a 500cc motor with almost twice the power. Heat, since its air cooled breaks down oil much quicker. I dont send my oil out for analysis so its hard to tell when I should change it. My rule of thumb is after the third ride. Plus my bike sometimes sits a month or so between rides which isnt good either.
    • By jay41198
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By kevinohio
    • By middlebrookgt
    • By Rick Shropshire
      I recently picked up a  2000 warrior 350 and it doesn’t have the air filter box so I was thinking about using a clamp on filter directly on the carb.  Anyone know what I need to get or where I can find it? The one I ordered goes in the box and won’t fit directly on the carb.
