My quad is spending the night!!!!!
Leave it to me to not have a winch I got my quad stuck & my buddy tried to pull me out with his 4wd grizz. My quad didn't move an inch. I had named the trails I ride on stealing wood trails for missing body parts of my quad I never found & now for tonight the trails has my whole quad pics well be posted tomarrow. I was going thru in 4wd so easy I thought I would give 2wd a try and played around a little to much spinning the tires and digging ruts. I'm 6 foot and I stepped in front of my quad up too knee deep in mud.
There will be pics to bad the woods photo contest will be over This may have been a good one for it. I have read it's hard to get these Prairies stuck. So that might make me the prairie odd ball. I will take a few still shots and the GoPro will be recording the recovery. I'm trying a way my friend of mine told me will work so pray it does. I dont have the money for a winch & I don't have a bobcat or a friend with 1 & it's to tight to get a four wheel drive truck in there to it.
I`ll be the first to tell you "Mud and 2Wd don`t mix well " lol :laugh:Glad to see that your out riding again !!! Can`t wait for the pics !!!
    • By NZrider
    • By jatho
    • By mkibbe
    • By jatho
    • By hardcastle
