Ok I am totally stumped on this one any ideas even if they are out of the box are appreciated.
My wife has a 2007 Arctic Cat 500 Auto and just recently after I changed the oil getting ready for the riding season the oil light, when started, comes on for a while and then goes out.
I can't figure it out for the life of me. I have a few ideas but I would like to hear a different perspective from the forum.
ok.. i got out a susuki service tips book that is for dealer servive dept. and it says that you should flush out the oil system ... and if that dosent take care of the oil service lite then the oil pump should be rebuilt/replaced ... and that is from a suzuki service tips manual/book that dealers have in the service dept.
Did u find out what the light is for?
Sent from my SGH-T959V using Xparent Blue Tapatalk
From what I have researched so far the AC 650 with the Kawi V2 was the only bike to contain an oil sensor. The light is still in the gauge pod because they used the same part number.
I am going to check it out this morning. I think I have it solved as of last night but I might flush the oil system next time I change the oil just in case.
    • By quadnut20
    • By tepin
      Why Riders Like It
      2. ITP Cryptid
      Features
      3. Outlaw 2 ATV Tires
      Pros
      4. STI Out & Back Max
      Highlights
      5. SuperATV Assassinator
      Features
      25-27 Inch Tires
      Bias vs Radial Mud Tires
      Bias Ply Tires
      ATV Mud Tire Maintenance Tips
      Final Thoughts
      any ideas how to correct
    • By randyoct
      Will the top end of a 400 fit a 366 the price is so much cheaper
