I just checked out members here in my viscinity by going to http://www.quadcrazy.com/browse/ and making the location New York. There are 89 New Yorkers here!!!
When you visit a member's profile...add them to your freinds list so you don't loose track like here: http://www.quadcrazy.com/user/Ajmboy/friends
Just thought I'd share...I think people don't know that they can search out other members.......in their area.....:biggrin:
  • 6 months later...
    • By Coyote251
      I am hooking up a speaker on the rear of bike and want to use a factory auxiliary switched plug and not have to cut into the factory wiring or add another switch. I have read a bunch of posts that say there should be an auxiliary 12V connector in the front and one in the rear. I found the one in the front when I hooked up my winch but cannot find any in the rear. I have seen some pictures showing one on the right side attached to the down tube behind the side cover, but there is nothing on my 2024. Can anyone confirm that there is a auxiliary 12V connector in the rear on the 2024 700 Xmr? If so, can you please tell me where it is (with a picture if possible)?
    • By anthonyd256
    • By dvs1961
