Just pick this up today, every thing working and runs great. My question is the rear end. I checked the oil level and found none. What I did see looks like dried grease. How do I clean this and what do I put into the rear end, grease or oil?
Can some one tell me where is the oil filter on my TRX300?
Also looking for service manual for my model.
My 1995 300 2wd used 30 weight motor oil and I believe it was 3 or 4 ounces. I would just add the oil and run it some and drain and refill.
The oil filter on my 95 was above the oil fill hole. Take the plastic cover off and then see the 3 triangular bolts that hold the housing cap on.
    • By sandman001
    • By Callaway
