Just pick this up today, every thing working and runs great. My question is the rear end. I checked the oil level and found none. What I did see looks like dried grease. How do I clean this and what do I put into the rear end, grease or oil?
Can some one tell me where is the oil filter on my TRX300?
Also looking for service manual for my model.
My 1995 300 2wd used 30 weight motor oil and I believe it was 3 or 4 ounces. I would just add the oil and run it some and drain and refill.
The oil filter on my 95 was above the oil fill hole. Take the plastic cover off and then see the 3 triangular bolts that hold the housing cap on.
      Hi everyone, first and foremost, I want to thank everyone for all the help I've received. I am so glad I found this community. I also wanna apologize if I'm spamming the forum, I come up with questions as I go, I guess lol. So when I got my Recon, the air box was missing the lid, held together by zip ties, and the filter was ripped and nasty. I have since ordered a new air box assembly. It comes with everything: the box,  lid, and filter ( the insert and the foam), and all the hardware necessary. This is the first time I've seen a metal filter inside a foam filter lol. However, my question is, I have read that you have to oil these filters? Every time I read it, it was always skimmed over, and I could not remember where I had read it. Is there a certain oil needed for this? Is the filter washable and reusable? Do I just stick the filter in oil, lol? Sorry if it sounds like a dumb question. Thanks in advance, y'all!
    • By sandman001
    • By Callaway
