I bought a used Chinese 110cc atv. The seller had no knowledge of anything on it.
It won't start but that's only one of my problems.
First I'd like to know what I have. Its a 2006 and manufactured by Zhejiang Chisheng Industry and Trading Co. and Imported by Seaseng Inc. It has a logo sticker on the front that say "MDI". It has a large number on the side that says "110ST." Even with this info I can't find anything telling me what this is. Is it a MDI? Is it a Seasheng? What the heck do I call this thing?
Second, after I know what to call this thing, where can I get a user and service manual?
Third, It did not have a battery so I took a shot in the dark and bought the only 12Vdc battery that would fit in the tiny battery compartment. Obviously I had no idea if it had the cranking amps needed. Where can I find out what type of 12Vdc battery to get for this thing?
Fourth, I installed the battery and the lights worked but the electric start would do nothing, even click a relay or anything. So I ran a wire directly from the "+" terminal of the battery to the starter post and it turned over but wouldnt start. I made sure the lanyard button was not the problem.
Fifth, The remote control just blinks when I press every button. Does the remote have anything to do with anything?
Thanks for any help !
I forgot to mention I dont think the handle bar switch assembly is bad because the light switch works. Also the key ignition switch seems to be fine too because the lights won't work without it in the on position.
I need to know what components are in between the "+" terminal of the battery and the starter because something is bad in that path. Is there a relay? a solenoid? an electric ignition module? I have no clue what is there.
I'm surfing the net and found a chinese atv parts site, so thats cool but without a schematic or a manual I don't know what I got. Anybody out there a chinese 110 atv guru?
those chinese built quads are always trouble. anybody i know thats had them said that they break all the time. its hard to say what it could be. every quad has a cdi box and if thats bad it won t turn over or do anything. theres relays and solenoids on them but it be hard to figure out which one it is without a manual. sometimes if the spring in the starter button will rust up and go bad. that can cause it not to start too.
Check your starter solenoid. (the switch that should be between your starter positive and your battery positive wires). If thats not the problem, check your fuses, as well as any neutral safety and shut off switches. You may have a switch on the foot and/or hand brake, on/off (kill) switch by the start button, or as was stated by rappy97, it coulc be a lose or shorted wire. Could also be a bad cdi.
  • 8 months later...
you have to pull the brake while pressing the starter button. There is a lanyard on the back of the machine, sort of under the rear seat that can be pulled to stop the engine, be sure the little button inside the lanyard is in all the way. Make sure your remote control has not killed the engine. There is a choke on the right side of the carburetor kind of up under the seat. You have to get down on your knees and look under the seat to see it.
    • By realpilot
    • By Cj Winds
    • By OldATVowner
    • By Rockbottom
      What should i test next?
      thanks ahead
