By TomJulio
My 1992 TRX00 recently stopped firing. I understand this is a common problem. I have ordered an aftermarket CDI unit. TJ
By vaneleus
By HeWasRidinDirty
By jeffrocdx
By Olchap
Thank you,
Olchap
