Similar Topics
By Makj44
As it should be easy to see I am not a four wheeler mechanic so I apologize for asking for help, I replaced my OEM carburetor with a aftermarket carburetor and with y’all’s help adjusted the air/ fuel and it ran great until this evening and I noticed a smell of fuel I inspected carburetor area and found a steady flow at the vent line on the bottom of the carburetor so my question is is the float the only thing that will cause this problem? Before I installed the carburetor I checked the jets for tightness and they all seemed fine?
By joshua91673
first post
josh ohio
By Makj44
Hello I have a 1999 Honda 300 4w/drive and I just replaced the Oem carburetor with a aftermarket carburetor after installing the carb on the bike it started great and idled like new one but when I shifted into first gear and tried to move forward it died, I shifted back In neutral and the wheeler started easy again I let it set there to see if maybe it needed to warm up but when I shifted into first and tried accelerating it died again, I am not a use to working on it and would appreciate any advise thanks
By 1998Zuki250
I know I know, There are seemingly 10000000 posts about the fuel issues on the late 90's Suzuki LTF 250 Quad runners. But I just got my 1998 and I only got it for $200. It idles but nothing on throttle. I cleaned the carb, and ultimately I had to order a carb, fuel pump and petcock as cleaning everything didnt help. Any suggestions?
By Whiterabbit
Hey all, from SW Virginia here. I just picked up a '01 Bombardier Quest 650 on the cheap (seller couldn't get it to start). After correctly plumbing the fuel pump (new pump the prior owner installed but had the hoses going backwards lol) and cleaning the carb and fuel tank, repaired all the batt - and batt+ connections she lives!! I had swore to the wife unit I wouldn't be dragging another "project" home but I couldn't pass it up, it had new tires, new starter, new fuel pump and low hrs. All's good after she took it for a ride! 😆 It rides like a tank, very stable and tons of power.
Similar Tagged Content
- 11 replies
- 698 views
1996 Yamaha Timberwolf Rebuild/Repair
By Chris Chitwood,
- timberwolf 250 yamaha engine
- 1996
- (and 1 more)
- 9 replies
- 3,243 views
- 3 replies
- 7,661 views
- 7 replies
- 4,273 views
- 1 reply
- 4,054 views
Gallery Images
