I was riding around the other night and it was shifting fine. No noises or anything....I stopped to pick up some stuff and then when in first gear it would rev so high and then it acted like it was in neutral. When the RPM's came back down it would engage 1st gear again. Reverse works fine. Any ideas??????????????????????????????????????????????
check the drive belt to see if it's worn. there is also a clutch adjustment. on yamahas, it is on the throttle side of the bike, looks like a nut with a slotted screw in the middle of it. not sure on suzukis, but it will be on the side of the motor/trans ...
    • By Joeguy
    • By jay41198
    • By Cj Winds
    • By OldATVowner
    • By oztrax
      MAX 4 6X6 2008
