I bought a 1997 polaris 425 6x6 and the guy told me the carb was bad....so I bought a new one..easy to install but wont run good..Where the breather or filter hooks to the back of the card there is a black I call snorkel...well if i sqeeze it closed a little bit and rev it up it seems to run 90 % better but as soon as i let go so its gettn all there air it pops and spits..cant even drive it....so i put a tie rap around it so it says closed some and runs ok....but then if I put it n reverse and back up it back fires....ca1n anyone help me out here? im stupid when it comes to wheelers... I dont see any adjustment screws for your fuel or air...why isnt there any..Help
yes about 1/3 throttle it seems like its starving for gas...i just bought the new carb...i do see a adjustment screw on the bottom side of the carb...it would be hard to adjust if that has anything to do with the air and gas....but was told under the top cover there is a needle valve that can be adjusted...right now i have the breather intake hole closed off a little just so it would run someway decent but i shouldnt have to do that..ideals fine though
    • By Thekevinjb
      thanks
    • By Dumass
