I replaced the pads on the back of my Warrior late of last year or early this year. Can't remember when exactly. Apparently I bought some crappy pads cause I wore them out already and messed up the rotor some. I have a new rotor and pads to put on but I have a problem.
I can't get the Allen Wrench bolts to break loose. I am hoping someone can tell me there is a trick to getting them loose. I could see my allen wrench twisting trying to get them loose. Actually messed up the bolts some.
Well got the rotor off. Two of the bolts came out pretty east. The other two that I messed with before was rough to get out. I was able to get one by beating a bigger allen into it. The other was some grinding on the bolt and grabbing it with vise grips. Bought some new bolt to at the hardware store.
Now I have a problem with the front left brake caliper. The slider bolt wouldn't move. Had to use a c clamp to push it back so I could get the caliper back on with the new pads. Was hoping after I pushed it back that it might free up and go back out. But not moving at all.
Thinking I'll have to pull the caliper off the quad and heat the slider bolt up and hope to get it loose. Pull it apart and give it a proper cleaning. We tried spraying Seaform Deep Creep in there but didn't move still.
At this point I would remove as many parts as possible and clean,grind,and lubricate them. If they are this hard to get off i would also do up the wheel bearings etc. This way you have a piece of mind on the trails.
I know you want to get back to riding asap but there seems to be too many corrosion gremlins lurking on that bike
Sent from my SGH-T989 using Xparent Blue Tapatalk 2
Oh yea we know the bearings. The rear end bearings are wobbly. Been working on the gremlins in the bike. I have a noise in the motor that's been there since I got it. Friend said it's either piston slap or the cam/lifters need adjusted bad..
Was thinking I should find another quad but my friend thinks this one will be going for a while. Just need to work on it some.
    • By Rick Shropshire
      I recently picked up a  2000 warrior 350 and it doesn’t have the air filter box so I was thinking about using a clamp on filter directly on the carb.  Anyone know what I need to get or where I can find it? The one I ordered goes in the box and won’t fit directly on the carb.
    • By shorty
      First ATV but owned 2 wheel versions all my (long) life. 1990 KLF300C for $500.. doesn't run yet but I'm an old automotive mechanic so not worried. Only a little concerned about the price of parts, certain this antique will need many
    • By Need-help-with-quads
    • By Norseman69
      Hi. I just bought an lt230 1993.  Ive started buying parts for a full rebuild.  But somehow beskepedal has been removed and pegs welded to where They are supposed to be screwed.    I was wondering if anyone have one and Could measure how far out the pegs are.  Like the peg the brake is put on and then peg outside of it.  And the one lower down.  So i can recreate them.
