I'm helping my 72 year old friend/riding buddy with his 08 Sportsman 500. We have full battery voltage at the battery and on the battery cable that connects to the solenoid. If I jump across the 2 posts the engine turns over fine. Also runs fine with the back up recoil. However, it doesn't appear to be getting any voltage to the solenoid from the key switch. Does anybody know of a common failure on these like a fuse or a circuit breaker etc. that supplies power to the solenoid?
I had checked at the weatherpack fitting at the solenoid and found no voltage to there. I don't know what wires carry voltage from the ignition switch but there are several at the switch that have full battery voltage so I'm assuming the switch just isn't passing voltage in the "start" position. Sound right? The ignition switch is $70 at the Polaris dealer so I want to be sure. Thank you for your input and service manuals guys.
    • By Sportsman500guy
    • By Ethan7387
    • By qcm413
      Hi,
      thank in advance
    • By alain
      I just got this quad from my father in law need some tlc. Will need a new battery and does not know the battery PN as I don't have service manual. When my father in law had it , it uses lots of plugs, never got it service to verified why , he just buy an other plug and was good for a other 4 to 6 months .
      Any one would havd answers would be appreciated. Thanks
