2000 Polaris Scrambler 400 - Anti-Freeze Problem
By
Atvspeeddemond, in Polaris ATV Forum
Similar Tagged Content
By Wali
I was riding my 400ex one day and when i shut it off to put it in the garage i tried to start it put again to drive it into the garge and it wouldnt start.I put a compression tester on it and its like 30 psi with out throttle and 0 psi WITH THROTTLE.
when i put my finger over the hole it fell likes its pulling my finger in more then its pushing it out
Has good spark.When i took it into the shop the said it had 1oz of oil in it and a tiny pit of metal shaving(TINY BIT LIKE 30 flakes)
When i try to pull start (push start/roll start) it made a not normal sound and wouldnt stay running.
If my bottom end is blow why would it still turn over fine,
Are my valves siezed or not working properly
or is my timing off causeing valves to not open in correct order with fire
PLEASE HELP all help is appreciated
By Hunter Aldridge
Some times I get spark some times not can ride then it just dies and wont get spark it has new cdi box and stator but I don't know if it has the pickup coil I'm at a loss
By William Sims
I have a 400 4by4 ,2005 green model,
wounding how many different CDI boxes will work on it
By jerry houston
Eiger 400 Suzuki runs fine Cook-Out joke face off the handlebars put it back on and will not start now will crank no no spark
By colin james
View File 2012-2014 Polaris Sportsman 400 HD Service Manual
This the factory service manual for the 2012- 2014 sportsman 400 hd service manual
Submitter colin james Submitted 02/08/2019 Category Polaris ATV
Similar Topics
By Susan Makowski-DeGraw
My quad runs, it starts up runs for about 10 minutes and then it dies if you let it sit for 10 minutes it’ll start back up ride for another 10 minutes and then die again, trying to figure out why it keeps stalling
By Ed Morris
I have a 2001 Quadmaster. Bought it from the original Owner. Its in Excellent condition for a 2001. The guy said there was a carb problem when I bought it. It seems like it is not getting fuel. I took off the tank, cleaned it, replaced the gas with fresh Gas, Installed a New Gas Valve. Then rebuilt the carb with a Carb Kit. Started it up and same damn thing, seems like its starving for gas. It will also backfire out the exhaust while trying to accelerate. Now the weird part. I started it the other day and it ran great. We went for a ride and it ran as if nothing was wrong with it. Started it the next day and back to running crappy again. I was like WTF !!! ... Anyone have any ideas of what the problem could be?
By vtech
I have a 1993 Bayou 400 4x4 and I have no spark. I tried 2 new plugs and nothing still.
I have checked the CDI black wires to body of the box for continuity and none.
It turns over but no spark, not sure where to go from there.
Any advise on what and how to check other components would be awesome.
Thanks: Garry
By texaskaw
been acting up for a couple weeks.running fine then dies,no spark at plug.wait few minutes start up again runs for maybe hours.also sometimes it will run great then it starts losing rpm.will not wind up to higher rpms then it will pickup and go for awhile.well now there is no spark any time ,nothing....
By Michael P
Hi i have bayou 400 when i turn it over i get one little spark and that's it? New cdi ,switch, and a used regulator/retifier,new battery any suggestions would be greatly appreciated
