Similar Tagged Content
By Barrysquad
Somehow I lost all of my spark on my 350Big Bear, its a 1990. It ran well for maybe 3 days! Thought it was the carb. Cleaned it 4 times. It was losing power at midrange. Got worse and worse. Finally nothing!
Are these good coils? I was thinking I could swap?
2002 Honda-200cc: primary 0.4(ohm-200) secondary 9.0(ohm20k)
1990 Yamaha-350cc: primary 0.8 secondary 11.0
By JenWal85
Hope someone can help with this one.
We took our 1984 Honda TRX 200 to the shop and they had it for about 2 weeks before they finally called and said that they had cleaned the carb and changed the battery and that it had started up.
We went and got it and when we got home it would not start so we called them, they said bring it back in, so we did. They called us the next day and said they changed the spark plug, and that it was running. We went and got it again and it ran when we drove it off the truck.
We parked it for about an hour because we were going to get ready to go on a ride. Well, it wouldnt start again.
So we called them and they said the last thing they could do was order a new CDI box and put that on. I decided to just buy it myself, so I didnt have to pay them labor again. We put the new one on today and its still not starting.
Does anyone have any ideas on what we could check to see what in the world is going on with this thing?
Please and Thank you
By cbbubby78
can someone tell me what could be the problem if the electric start doesn't turn the motor over but sparkplug fires like crazy but the pull rope turns the motor but no fire on spark plug. thanks for any advice in advance . cbbubby78
By invest0rs
Hello everyone. I am new to the forum and am hoping someone out there can help me with a no spark issue I am having with my ATV. I have the service manual and I have replaced/checked everything that I know how with the exception of the Digital Igniter Unit. Does anyone know how to test this item to verify if it is bad or not. Thanks in advance for your help. Stacey
By surbike11
Thanks in advance for any help or guidance. I was out riding the other day and lost all spark. I have read every thread on every forum that I could find and have not found an answer. I have checked the codes and its 00. I have ohm metered the stator and crank sensor. I have also replaced the coil pack. I have inspected and cleaned all connections. I do not mud the machine, it is mostly used at the hunting lease for working plots. When I installed the new coil I held the plug on the side of the engine and got 2 little sparks when first turning over and then nothing again. When you turn the machine over like this it eventually flashes EFI on the screen. I checked both wires that go to the coil and noticed that both have ground continuity. While turning over the blue and white one cycle from around 1v to almost 12v. The battery has a full charge and I am at a total loss. I took the kill switch apart and all looked well. Oh yea and all fuses are good. Help me please I am getting very frustrated. Thanks
Similar Topics
By vtech
I have a 1993 Bayou 400 4x4 and I have no spark. I tried 2 new plugs and nothing still.
I have checked the CDI black wires to body of the box for continuity and none.
It turns over but no spark, not sure where to go from there.
Any advise on what and how to check other components would be awesome.
Thanks: Garry
By texaskaw
been acting up for a couple weeks.running fine then dies,no spark at plug.wait few minutes start up again runs for maybe hours.also sometimes it will run great then it starts losing rpm.will not wind up to higher rpms then it will pickup and go for awhile.well now there is no spark any time ,nothing....
By Michael P
Hi i have bayou 400 when i turn it over i get one little spark and that's it? New cdi ,switch, and a used regulator/retifier,new battery any suggestions would be greatly appreciated
By JonBat68
I have a 99 250 Quadrunner. Currently has no spark. It would run for 5 minutes, then shut off. After it cooled down about 20-30 minutes, it would start again. I ordered a new stator and found the old one was damaged (copper windings broken) I installed the new stator, filled with oil and now it has no spark. Any assistance would be helpful
By Tiffany Rowland
I am working on a Honda sportrax I just got my daughter for get birthday and the reverse and neutral light are not working. When I traced the wire down I saw that it wasn't plugged in but I don't see where it is supposed to connect. Does any one have a general idea of where I should look?
