No the pump is still on the quad that is what i did i just ran a straight line from the tank to the carb but it doesn't serm to be getting gas. If i take thr fuel line off gas comrs out the petcock.
Sent from my SGH-T989 using Tapatalk 2
Here's a trick.....but don't tell anyone I told you this cause it can be dangerous. Try having a buddy pressurize the fuel tank a bit while you crank it over. A slight amount of pressure in the tank will mimick the fuel pump. Just hook a line from a compressor to the vent on the cap and give it a little shot. DO NOT OVER PRESSURIZE IT!!! It will blow itself to peices!! All you need is SLIGHT pressure. This works , when the engine seems like it's dying have your buddy give it another little shot of pressure & see how the engine reacts.
    • By jay41198
    • By LMI
    • By kevinohio
    • By buriedpast
