I bought an 07 yfz 450 Bill Balance edition last november. It runs great, and has some mods that i cant quite figure out. I am pretty sure it has a big bore kit and a stage two cam on it. The problem is that the coolant leaks out of a tube that comes from the bottom of the right side of the ?crank case? (motor). It wasnt bad at all when I got it, but now that I have ridden it more, it starts to leak immediately upon starting. Even when its cold, and will continue to leak bad enough to empty the reservior under the seat in a matter of minutes. Any help would be great!:aargh:
Are you sure it's not an impeller seal that has gone bad causing a leak in that area? Seems common on those. Check out this video:
[ame=http://www.youtube.com/watch?v=f6M8Wc6uQZ8]yfz 450 coolant leak fix. Impeller seal replacement Part 1 of 2 - YouTube[/ame]
    • By ButchM
    • By dkgg5755
    • By Sha35297
      I have this bike in my shop for a customer. It was sunk completely under water and left running until it killed. I did a complete engine rebuild. Replaced all bearings, crank, oil pump, and various other components. Engine starts and runs great. It will shift up through all gears perfectly in automatic and in ESP, but when slowing down it gets to 3rd gear and the MIL "-" light comes on and stays on. No flashes or anything and it will not shift gears. Kill the engine and restart in ESP mode and it is able to shift to neutral and start over. Does the same thing while down shifting in ESP mode. I replaced shift angle sensor with no improvement. Checked oil pressures as per repair manual "74psi" and higher with higher RPM's. With no MIL codes to point at an issue. I am at a loss as to what else to check or replace. Has anyone else ran across this issue?
    • By 97kingquad
    • By shorty
