Similar Tagged Content
By Trenton
Hello. I am a new member as of today. I had a quick question to ask. I recently was driving mt HONDA RANCHER 2004 GPSscape 400 and my display stopped working. I was driving the atv and all of a sudden the speedometer and the service lights went out. Also the lights stopped working. I am still able to shift gears, change from 2wd to 4wd, and can still select if I want EPS or Auto. I have checked my fuse box and have changed a few of them around. It did not change anything. I was wondering if anyone had any idea of what had happend. Thank you for your time- Trenton
By LTZ-Zach
So i was riding the other day and my quad randomly shut off. It started back up and ran completely fine for a little while and then it started idling terribly.
I cleaned the carb and changed all the jets and everything except the float due to the rebuild kit not coming with one and it actually runs worse then it did before.
It will run and idle decent now but when I give it gas it dies.
Does anybody know what could be wrong?
I also changed the spark plug and air filter along with the oil and oil filter.
Similar Topics
By Viking
There's an electrical cable connected to the front brake lever. The parts list calls it the front stop switch assembly. There is no stop switch on this side of the handle bars. Seems to be activated by the brake lever. Anybody know what it does?
By Blenderite
Hello guys! New to the forum, and fairly new to ATVs. I've driven them, but never owned one. Now I do own one. Just picked it up today. It's a 1999 Yamaha Big Bear 350. It's been through some stuff. The guy I got it from told me the previous owner removed the front diff because he didn't want to replace the half shaft. So it's 2wd, even though it's supposed to be 4x4. Lovely. I can deal with that for now.
More importantly, I need to get it running. The carb needs to be rebuilt. The guy I got it from said he sprayed it all out and it still didn't work. I'm concerned he might have damaged it or not put all the parts back. I was looking at a replacement carb, and the OEM parts is $600. I'd rather not spend $600 if there are any other options. I have seen carbs on Amazon and eBay that are in the $40 - $100 range that say they fit. Anyone have experience with these? I'm going to get a rebuild kit for the current carb just to make sure that won't fix it.
Thats the first thing with it. Secondly, it was completely rewired. I need to find a original wiring diagram so I can put it back how it was, with a key and all. Currently it's wired with just a rocker switch. Any sources for a service manual that would include wiring diagrams?
Thirdly, is the Big Bear 350 a good atv? I picked it up for $700. It does start and run when you spray starting fluid into the air intake, so I am not concerned about the engine being bad. I plan to use it for the farm, running around and carrying things with it like minerals and feed and such. Not really for mudding and things like that. How good is the 99 350?
I am certain I will have more questions as I examine it more, but that's all for now. Thanks in advance for the assistance!
-Blenderite
By Arizona
Just a couple of things since i get various atvs.
They always need seat cover and always need oil and other minor items.
My question is Do you buy any specific motor oil for them, i heard you must get atv oil or will mess up the clutch.
Not sure if correct but didnt want to find out hard way. Is there a cheaper oil or can you use regular motor oil?
Next they always need a new seat cover, any good places to buy bulk or cheap vinyl to re do the seats with out spending
30-50 dollars on a specific cover?
whats you go to places for parts, i use amazon, ebay any others that offer a good deal?
that goes for hard parts or just cables and or clips, wiring, bolts etc no wrong answer here.
always looking for new ways to find parts for the older atvs. TIA Az
By weblex
Friends, being the owner of a far from new ATV, I often come across a search for various owner's manuals, service guides, parts manuals, etc. It is not easy to find suitable documents for every quad. Therefore, I present to your attention a website that contains various instructions for ATVs from well-known manufacturers: https://www.ATVownersmanual.com
Currently only 3 manufacturers are represented here: Can-Am, Polaris, Yamaha - and only about 1200 instructions for various models. Little later other brands and missing instructions will be added.
What will be convenient for you: all documents are in PDF format. If necessary, you can download them to your computer and use offline. The documents are structured by brand, year and model. There is no advertising (yet).
I am happy to hear criticism and recommendations. If you have missing or rare instructions, send them to PM or to the website's email: info [...at...] atvownersmanual [...dot...] com.
By Venom
Does anyone make aftermarket engine parts for the Suzuki Quadsport LT-Z50?
Pistons, Valves, etc...?
I have found rings and complete gasket sets.... I need an oversize piston kit and valves..
One company is selling a piston, but upon further inspection it is an LT50 piston that they are saying is for the 2006 Suzuki Quadsport LT-Z50. Yet the LT50 Piston is not interchangeable with the LT-Z50 according to the pistons listed by Suzuki.
Any help would be appreciated
