Similar Tagged Content
By Guest Fox300exchic
If we had a dollar for every time the question “Which is really faster, the 700 or the 450?” shows up in our inbox, mailbox, or voicemail, we’d be putting this magazine together from a bungalow on a barely inhabited tropical isle named Quadhama.
http://www.quadmagazine.com/quad/features/article/0,24942,1603755,00.html
By bodatiouskid
Have a 2002 Polaris Sportsman 700 that only has 34mi. on a carb & ring job.
Cut the gas off today to drain carb.Now engine will not idle.If I open throttle will run,but let off & will cut off.Can screw idle in with no change.
What happened? Why did this happen when fuel ran out?
Please help me,my ATV is a daily driver.
Please help!!
By toonces
I'm wanting to run Shell Rotella T6 synthetic in the 700 Griz but I can only find it in either 0W-40 or 5W-40 weights, and the manual says it's ok to use everything BUT those weights...5W-30, 10W-30, 10W-40, 15W-40, 20W-40 and 20W-50.
Would it be ok to use the Rotella 5W-40 or do I need to stick to what's specified in the manual?
By gyminis
i have a 2009 grizzly 700,replaced the fuel pump and filter,replaced the spark plug and checked the air filter for a mouse house! it runs then shuts down,wont stay running,does the fuel line need to be primed and air free to run properly or am i missing something obvious??????????????
Similar Topics
By Michael Thornton
Why does the 2001 grizzly not have com bearings or something to protect the head.
By NoDeer
I have an older (1987) Yamaha Big Bear 350. I have arthritis in my thumbs. Is it possible to replace the accelerator with a motorcycle accelerator (ie. twisting the handgrip)? This would be more comfortable for me due to the arthritis.
By Halley
Could anyone take a look at the picture and let me know if I’m needing to replace the actual throttle cable or the throttle handle ? Its for a can am 2018 outlander XMR 1000. It’s in limp home mode and throwing code P1619
By stuman6669
my buddys 02? warrior cuts out as soon as you give it throttle. it stays running, but it missfires and pops through the exhaust. it returns to idle and idles fine. the timing looks ok and we have swapped the carb with no change.its been sitting a while waiting on carrier rebuild, it ran fine before that. any ideas?
By BUKNDUK
Hello
I want to paint the body on my 1999 Suzuki King Quad 300. The original color is Tan. Does anyone have any experience in painting smooth plastic. What preparations need to be done,maybe sand body to ruff it up so paint sticks or some type of chemical cleaner also can you please recommend the correct paint I need I would think something flexible
