My 2013 Drag Bike
Got it together last week. All powder coating was done by myself, with the exception of the swing arm and subframe.
Barker built motor, +1 head, Cuervo cam, Sredrum throttle body, CP Tech piston, Troywcc EVAC valve
Templeton drag pipes
Skat Trak 76 rollout 12 paddle haulers
Custom drilled rotor
QuadTech foam/cover
AM Chassis +6" "T" stem and -8 width +6 forward single arm rigid front end
ASV C5 clutch lever
Turbo Chassis +4 swing arm
Direct Drive CNC 10x2" front wheels W2 (spindle mounts)
Sandtoyz Unlimited 18x3 front tires
Custom aluminum "bumper"
Custom lightweight rear caliper
Fly Racing start button
ECATV tether
Modified lightweight subframe
Big thanks to Quality Powdercoat (qpcoat.com) for the subframe powder coating and swing arm coating, Brett (sand2kinc.com) for helping me out with some tips when putting together... And numerous members from other forums for helping me get the parts to build this.
It weighed in at 312lbs wet with this 25lb axle, a 12lb aluminum JJ&A axle is enroute.
Very nice project Rappy. An expensive one I bet. Are you going to race it?
Thank you!
Yes, it's a total money pit lol, could be spending money on worse things I suppose.
Yep, it's strictly a racing quad now with the rigid front end, no dunes or trails for me!
Couldn't get the dumb thing to run half right today. Best was a 5.52, which should be more like a 4.7x.
There is no fuel above 6500rpm. Will have to figure that problem out tomorrow. Here's a quick video-
[ame=http://www.youtube.com/watch?v=nxWvllljH2k&sns=em]Drag Raptor Phil's 5/18/13 - YouTube[/ame]
Last weekend and yesterday, and tomorrow actually. Last weekend, took first place in the mod class, there were probably 10-15 bikes... Unfortunately no timers. Yesterday was T&T at West Michigan Sand Drags. Ran a 5.11 off the trailer with it having little traction and messed up gearing, ran a 5.0 at 57mph, and it was all down hill from there. It just spun like crazy!
Last week-
Yesterday, getting zero traction-
    • By jatho
    • By kiriyaaoi
    • By p5200
      Can someone please tell me what size socket I need to remove the valve cover? Thanks! 🙂
    • By afterburn
