Dummy & a quad
I went to move my daughters atv and had trouble getting it to start. I didn't think it had been rode enough to be out of gas I was wrong I had truned the fuel cock to what I thought was res. & I was turning it to off. It took awhile before I realized what I was doing! Add gas and it will run. My brain fart for today.:confused:
about 17 years ago I test rode a Honda big red atc and didn't buy it because it pulled bad and at the time I didn't know that low air pressure could caused it. The seller said it was a low tire but didn't offer to put air in it & let me ride it again and it was at a shop so I didn't think he was telling the truth. If I knew as a seller the tire was low I would taken care of that before they let people ride it. I would have bought it if I knew he was telling the truth.
Whats funny to me the Forman we just bought is a foot shift. When I was asking the seller ?s he said it had a hand clutch. His father bought it new and it was given to him but he said he never rode it much so when we got there and looked at the quad I said that's a rear brake not a clutch he insisted it was a clutch. It would be funny seeing the quad stop every time he went to shift gears and still not know its a brake. He was 20 something yrs.old .
I here you! He said he only rode it about 2 times him self and he had it at the Honda dealer to be serviced. I think he sold it for his Dad. He knew nothing about the atv. I ask about oil changes he didn't know of any so I got a filter & oil on the way to pick up the quad. The oil looked like it had just been changed. He didn't even clean out the storage compartments. It came with bullets but there was no rifle.
    • By Werewolf
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By oxidized_black
    • By jashadams
