1995 kodiak 400 leaking oil
Kodiak95
I have a leaking rear end and when I removed the plug it was over full and running out....I had to add 1 qt to the engine over the weekend and the engine doesn't leak or burn oil....can the oil travel down the drive shaft tube from the transmission to the rear???.....if so how big of a job is that to fix?......thanx:aargh:
Ive never heard of that happening (engine oil getting into the diffs. ) or being possible, but..... an over filled diff. could cause gear oil to leak thru the seals. Try running it with the proper fluid levels & see if the leak goes away. The seals may not be damaged, just where over stressed from the fluid level being so high. They really arent designed to operate in a submerged environment.
Edited by Mudflap64
oops....
I got it jacked up where I could see today and removed the skid plate....seems both axle seals are leaking....not sure but maybe the previous owner knew it was leaking and over filled it....I have new seals and bearings coming for it....I'm not gonna be swamping this old ride....I just wanted a machine too cruise the trails with.....thanx for the replies....I'm sure I will have questions on other projects....
    • By BruceG
    • By HSTAR
    • By DarkRider
    • By dalton7545
    • By alexwv1863
