Help, The carb started leaking gas out of my 2000 300 so I shut the gas off. 6 months later I get a chance to check into it and the needle is stuck in the brass seat. New needle and cleaned the carb good and now the gas won't shut off. Fills the air box/cylinder with gas. I had it apart 3 times and nothing I did seems to solve the continual gas flow. I really don't want to spend $379 for a new carb. Any suggestions? I did notice the tangs,arm that hold the float pin are really wore out, lots of slop for the float pin.
Put a piece of hose on the gas inlet, blew through the hose and lifted the float and it will shut off air being blown. But, hook the gas line up to carb and gas just keeps running out of it.:no:
Ok put the carb kit in and it got a little better but still leaking gas into the cylinder sporatically. Found out that the diaphram in the carb also needed replaced. Carb issues resolved but not the voltage regulator/rectifier went out. Get that replaced and it aught to be good for another 8000 miles.:yes:
  • 3 months later...
Still running great. Just wanted to let everyone know.:yes:
Where did you get the carb kit from I haven't been able to find a carb kit for that 4 wheeler
Ebay, but the kit was for CA and not CO so the jets were wrong. So now that we have the correct jets and adjusted the valves I think we have the 250 running again.:yes:
    • By LCP92
    • By middlebrookgt
    • By DPDISXR4Ti
      Thanks...
    • By alexwv1863
      I believe the Kawasaki is either an '03 or '04. Green automatic with shifter on the right side. Rear differential was bad, so I replaced it with another. The 4 wheeler rolled in neutral when I parked it in the shop to work on. Took old diff off and replaced it with another one. The diff I put on, turned before I put it on the bike. Once I put it on the bike, the rear end wouldn't move at all. It's like it's stuck in gear. Bike is still in neutral. I've tried rocking the bike while trying to put it in high, won't budge. Can anyone tell me of something to check or try? I haven't opened up the transmission case yet to see what's going on. What should I be looking for?
