"Belt" message appeared on console screen. Does that mean a loose belt and either needs tightening or replaced? I kept going and turn off ignition. Could not start again. Not even a grunt, new battery. Partner jumped and I was able to do all my errands and drive home. (Total 2 hours). battery still dead. What am I looking at as to possible diagnosis and corrections?
The "Belt" indicator was for the V-twins with the Kawasaki motor. From your description that does not sound right. Sounds like the pod got messed up I don't think your machine has a belt sensor. It meant it was time to change the belt.
You have t find out what happened why it wouldn't start back up. Your battery could have just up and died.
Mike
Mike. This is an embarrassment. I did not get the jump start by using the solenoid post. Not the battery. I left the battery cover in place since we were on the trail. When I got home I just plugged in the charger to a plug outside. Tonight I tried to start and it was still stone dead. Here is where I got embarrassed. Removing the battery cover I found the positive bolt and nut gone and the cable was dangling loose. The battery is fine and the trail ride tonight uneventfull. So this is a very long story to feed and explain my red face. Sorry for taking your time. Yes, you can chuckle at my expense.
    • By LMI
    • By Rockbottom
      What should i test next?
      thanks ahead
    • By Mister907
      I have a 2015 Outlander L 500 max.
      any way to change the start up message in the cluster WITHOUT taking it to the dealer and paying $100???
