Very good to all. Forgive my English, I'm from Spain. Some time ago I'm in this incleible scene. Passionate about these machines. I have a Grizzly 700 and Raptor 350. I look forward to sharing with you my videos in the appropriate section. I hope you like it!
Best regards.
    • By Gtc4d
      Thanks.
      Todd
    • By jordan_ATV
    • By Louznmemind
      (Question is at the end if you want to skip my blabbering) I got this unbelievably well taken care of Grizzly 350 in for a carb clean, it belongs to an elderly couple that bought it brand new in '07. Apparently whoever has been doing their oil changes for them never checked the air filter..
      Obviously it got debris in the carb, it would still run but only idle with slight choke. I've taken it apart and cleaned it, have new o rings, gaskets, etc. As far as the mixture screw is concerned, I'm assuming I obviously need to remove the plug. I'm mainly a lawn equipment guy, I've worked on slide carbs in the past but never an unmolested one with the plug still intact. I hate to mess with it as the carb had very little debris but I'm sure the o ring needs to be replaced at minimum. Finally, the question: what's the best way of removing the plug? I DO NOT want to mess up this carb..
    • By Louznmemind
      Can someone please tell me the fill point on the drive axle? '07 Grizzly 350, straight rear drive, not independent. Thanks
      My 2004 Yamaha Grizzly 660 seat is a mess, torn up, cracked, and I have been duct taping it for a while.  I bought new vinyl for $35 and need to do it one day. A new seat used to be well over $250 but now its under $100 so I couldn't resist. I got it on ebay with a 10% off coupon for $85.05 plus tax. https://www.ebay.com/itm/146040022154
      In case anyone is looking for a new seat for their Yamaha Grizzly 😁
      I saw it on Amazon as well for under $100
