Bought a 01 bear tracker and a trailer from a local guy last week. I rebuilt the carb 2 days ago and ran damn near perfect for 2 hours. Parked it and came back the next day. It suddenly won't hold an idle at all and pops when I'm going downhill or at a slow speed. Almost like I'm dragging the whole power train with the weight of the ATV. It still has decent power (80-90% maybe as it is now) but I can't figure out why it's popping and won't hold an idle suddenly. even with messing with the idle screw next to the bowl on the exterior of the carb. No changes. . ANY ideas would be great. I'm far from a carb king, but I've never had this issue before. The fuel was bought 2 days ago and it has a brand new intake manifold as of yesterday when I rebuilt the carb (whole rebuild kit). I sprayed around the carb and did not find any leaks.
 Thanks y'all.
I actually came across that thread before I posted here. None of his solutions made any difference on mine. I found the problem this mornin, apparently the BRAND NEW (like installed less than 24hrs ago) intake manifold had a gash on the bottom end of it on the rubber. Never thought to look at it since it was literally brand new. Just got off the phone with the parts company and have a replacement on the way. Goobered it up with JB weld for now so my boy can at least ride it for a bit. Just waiting for it to cure and hopefully she'll ride like new. Thanks though
    • By WeeBee
    • By kellogs
      Hello,
      Need to buy the ATV + ramp.
      What do you guys think ?
    • By OldATVowner
    • By pastorjeep
      Need a little help fixing a no spark issue. 2002 BT with the 2 wire ignition switch. I have 4 stators and 2 CDI's and 3 coils to test. The new stator reads 218 ohm, and .2 ohm, the one that came out of it reads 50K and .2, the other is 132 and .2. All of the coils are 0.00 ohm, and there is no way to test the CDI that I know. I have also confirmed the replacement stator pins match the factory locations. I did try to test milli-volts at the coil to see if it was getting any signal from the CDI but nope. IDEAS?
    • By Frank Angerano
