Past the perimeter
By mikeexplorer
By DayBreakJim
20230725_171507.mp4
By Ulfthednar
Just a quick test video while I'm learning to use my gopro (really, $250 discount I couldn't pass it up).
This is from my side drive to the top of the property.
The Dog loves the runs.
No snowflakes were injured in the production of this video.
https://youtu.be/tKjBFuHCkM0
By Matv88
Bought it new for my son. Pretty unhappy. Very very very lean at idle. Then there were a few things the dealer should have done during assembly including choke cable adjustment and rear brake adjustment.
I'm going to drill out the tamper proof plug and adjust the idle/air screw to see if that helps.
