I bought a 2008 arctic at 366 with 120hrs. When i red line it in neutral is smokes blue a lot. When I put it in high range it has problems getting over 35km/h. I bought it and had to clean the carb. It ran ok after i cleaned it. Not I have this problem.
air rulers fine. I cleaned the carb again and just before the carb there is an air box. The box was FULL OF DIRT. I cleaned it out and it runs great but still smokes blue. I'm thinking sand or dirt got into the cylinder and scored the cylinder walls.
Ok so I definitely need to redo my rings because today I started it up and it smokes really bad. Does anyone have a price on how much this costs if I do the rings myself?
  • 7 years later...
I suspect it probably would not fit , the 366 is a Kymco engine and the 400 is a Suzuki engine. Even though the engine specs are close to the same i think the chances of a Suzuki top end fitting a Kymco engine to very very slim. Could be wrong, never tried it.
Correct, the 400 is Suzuki, the 366 is Kymco.  I had a 2010 366 that my girl rode, Sold it this summer after buying another machine. It had 11,000 miles on it and still ran well.
Her current machine is a 2017 400 Alterra, which is basically the same machine as the 366 with different plastics.
15 hours ago, jen said:
The 400 altera i a Kymco motor?   Taiwanese.
The 366 model (2008-2012?) and the Alterra 400 (2013-2018) were Kymco motors.  I don't know if the newer 400 model is, they changed it now to the 425 which I think is the re-designed model which would be Arctic Cat / Trakker motor.  Some of the parts on her Alterra say "Kymco" on it.
My 450 is an Arctic Cat motor, my new 600 is the re-designed machine (trakker motor)
Kymco is a good brand, in fact Michelle's FIRST quad was a Kymco (2008) it was OK, but being a sport model, she got beat up on it since our local terrain is rocky. In 2010 I got her the black Arctic Cat 366 model which was much better. Sold the Kymco and to this date, it is still running.
    • By Cj Winds
    • By OldATVowner
    • By tepin
    • By Shorty51
    • By wilmpie
      hi everybody
      thanx in advance
