Kawasaki bayou 400 no spark
Ok so I was wrong on the reading.  I’ve attached a pic so you can see the plug and the test result.
Possibly a broken wire on that trigger coil it’s self where it was soldered during manufacturing ? Defective maybe ? Check the plug as well, and maybe test further down the wire closer to the engine to make sure there is not a stretched/broken wire.   Other then that you may have to pull the casing off and check it out.
  • 10 months later...
  • 3 months later...
single spark like Jason above mentioned is normally due to residual charge in the electrical system exiting the plug, meaning it's not an actual spark, it's just a couple volts provided by the battery.  Most commonly caused by a faulty CDI.
@William White Start a new topic and give as much information as you can.  Pretty good chance someone in this forum can help, several of us have owned quite a few Bayou's over the years.
    • By DarkRider
      CARFAX https://www.carfax.com
    • By huntindog
      TIA
    • By Werewolf
