First Quad...First Project
if your really looking for a deal on tires keep an eye on ebay for a set of razr or razr II take offs from a race team. i got a set of razr2 fronts on baja rims and razr rears on ITP 10" beadlocks for $191 (after shipping)off there with 75% tread and no holes!!! Racers post them at decent prices to and sometimes you can even find them with up to 90% tread left, i know some teams that dont put more than 2 races on a set then sell them for that fresh edge on the lugs. keep an eye out on there you never know what you might stumble across.. I would go with maxxis over the ITP holeshots, they have a lot more durable compund, and get awesome traction too!! Good luck, and great job on the silver bullet!!:yes: i'm going to take a nap now from getting caught up on this novel of a post..lol. take care!:bow:
wow.
just made a amazing discovery.
through this process. i have been secretly searching the internet for nerf bars that will fit on my bike. i see them on scrammys all the time. and wanted to know what would fit. WHAT MODEL NERF BAR WILL FIT ON MY TBLAZER!?!?! it drove me crazy!!
untill tonight!!
i found out surfing the net. that rappy and shee bars WILL FIT with MINOR modification.
i can get a set for 80$
the main question is. should i get the nerfs instead of the CDI and wait untill xmas to buy the CDI.
o yeah my parents havent ordered my stuff yet because of money troubles.
im SO leaning twords nerfs. i HATE floorboards. they send a jarring vibration up my legs.
    • By Johnfj44
      The stock driver seat cushion is separated at a seam. I took the seat apart and found that the material has torn and cannot be re-stiched. I'm trying to find a replacement seat. Any suggestions? Hoping for a used seat but couldn't find one on Ebay.
    • By Werewolf
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By mga
    • By 86ccord
