Hello All, Finally got around to messing with quad. I found bad grounds & faulty coil. Ordered new today. Stole coil from other quad and made spark......woohooo....👍🏻. Well I temp installed new coil and made spark. Figured I would pour little gas in carb to see if it fires. No fire ..tried a little starting fluid just to see if it would fire. No fire.. well if I have spark, add clean fuel but No fire or booms from quad what’s so ever. Any suggestions..
Yes you should have at least a little bit of a fire if you have spark. Is it possable that your  temp connections are good ? I would def take the carb apart and clean it just to get that out of the way. As far as spark goes is the plug fresh? If not put a new one in.
  • Admin changed the title to Kawasaki Lakota 300 No Fire
  • 3 months later...
    • By RGS
    • By RadRob
    • By Rich1028
      I Crashed My Quad
      Below are Three Videos.
      5 broken Ribs
      1 Punctured Lung
      1 Broken Collar Bone
