OK ya'll.My son bought this thing and was told its a Kaw Bayou 300. Maybe. I cant find any numbers on it.The one tag I did find its so faded as to be unreadable. Its a long shot but maybe someone can help ID it. Thanks in advance.
Dont know Kid bought it with the hole in it and plugged it.
I could maybe see a hole underneath,but on top?
JacobSlabach,as far as I know,besides the hole in the rearend,it needs plastic and rear axle bearings. Thats why I needed to know for sure what it is. A model year would help too,lol
Don't knock patching something till you tried it. A rod came loose in my hotrod Briggs go-cart motor, hole size of a golf ball, bent a plate of aluminum, drilled 4 holes slapped on the silicon bolted it up. Worked like a charm. Hahaha I had to try.
  • Haha 1
    • By marlon smith
    • By dkgg5755
    • Guest
      By Guest
    • By jordan_ATV
    • By T37Mark
