Hey I'm new to the Forum but I just wanted to talk about my Scrambler I just picked up and when I first picked it up I thought it was okay but after I got home and everything I noticed it's very hard to shift into drive neutral reverse it is possible to shift into those gears but it's very stiff like and it takes a lot for it to actually engage to move forward. In Drive when I press on the gas it takes a while for it to actually start moving in the RPMs go up before it starts moving I inspected the belt it looks fine to me I checked the transmission fluid and it was low so I put some. I just hope transmission is not out just curious if you guys have any ideas
  • Ajmboy changed the title to 1997 Polaris Scrambler 400 4×4 Hard To Shift
Welcome to Quadcrazy, have you checked the clutch? There are plates and springs that over time or over abuse wear out.  May need an adjustment or replacement parts   As far as the hard shift goes I would ask if the rpms are up? Maybe lower the idle and see if that changes anything
Check out the repair manual and you will find exactly what’s involved inside the manual in order to repair.
You're checking the gearbox oil level, not transmission. Either it works out doesn't. If it's difficult to shift into gear the linkage might need to be adjusted. If it grinds when you're trying to shift it, the engine idle is too high.
You have a CVT system, that's the transmission. Sounds like combination of worn belt and clutch springs. I would download the service manual and go through the troubleshooting section.
check that your brakes are not locking up or rubbing.  the older cvt polaris' bikes do have to have some throttle to get going.  a good way to check that the brakes are not rubbing is to push it in neutral.
  • 3 months later...
    • By hengstserepair
      Nuetral: Runs as expected
      Lorne
      View File 2020-2026 Polaris Scrambler XP 1000 S service manual
      Download the 2020-2026 Polaris Scrambler XP 1000 S service manual PDF for complete factory repair, maintenance, troubleshooting, and diagnostic information. This comprehensive Polaris Scrambler XP 1000 S repair manual covers all major systems including engine service, EFI fuel injection, transmission and clutch repair, AWD drivetrain systems, suspension, steering, brakes, electrical troubleshooting, wiring diagrams, torque specifications, and factory maintenance schedules.
      Designed for high-performance ATV owners, mechanics, racers, and DIY enthusiasts, this factory-style service manual provides detailed step-by-step instructions and diagrams for servicing and rebuilding the Polaris Scrambler XP 1000 S sport ATV.
      Topics covered include:
      Polaris Scrambler XP 1000 S engine repair
      AWD and differential service
      Suspension and steering repair
      Brake system maintenance
      Oil change procedures and service intervals
      Popular related searches:
      2020 Polaris Scrambler XP 1000 S service manual PDF
      Scrambler 1000 S wiring diagram
      Polaris Scrambler torque specs
      Scrambler XP 1000 S maintenance schedule
      Polaris Scrambler troubleshooting guide
      This Polaris factory repair manual is ideal for riders looking to maintain, troubleshoot, repair, or upgrade their Scrambler XP 1000 S for trail riding, mud riding, racing, dunes, and extreme off-road performance.
      View File 2018-2026 Polaris Scrambler 850 / 1000 service manual
      Download the 2018-2026 Polaris Scrambler 850 / 1000 service manual PDF for complete factory repair, maintenance, troubleshooting, and diagnostic procedures. This comprehensive Polaris Scrambler repair manual covers all major systems including engine service, fuel injection, transmission and clutch repair, AWD drivetrain systems, suspension, steering, brakes, electrical troubleshooting, wiring diagrams, torque specifications, and factory maintenance schedules.
      Designed for DIY ATV owners, mechanics, racers, and Polaris enthusiasts, this factory-style service manual provides detailed step-by-step instructions and diagrams for maintaining, troubleshooting, and rebuilding the Polaris Scrambler XP 850 and Scrambler XP 1000 high-performance sport ATV models.
      Polaris Scrambler 850 engine repair
      Polaris Scrambler 1000 service procedures
      AWD and differential repair
      Brake system service
      Electrical diagnostics and wiring diagrams
      EFI fuel injection troubleshooting
      2018 Polaris Scrambler 850 service manual PDF
      Polaris Scrambler 1000 repair manual
      Scrambler XP 1000 wiring diagram
      Scrambler 850 maintenance schedule
      Polaris ATV service manual PDF
      This Polaris factory repair manual is ideal for trail riders, mud riders, racers, and ATV owners looking to keep their Polaris Scrambler 850 or 1000 running at peak performance on the trail, dunes, mud, or track.
    • By TomJulio
    • By jeffrocdx
