New Yamaha Rider from Bulgaria
Asen_77
Our last ride was about 100 km total. With full tank I can go around 100-120 km, but just to be safe I am taking some small ( few liters ) additional fuel. Now we have plans for even longer trip with Gas station on the half of the road, so we will refill tanks :) .
Yeah, that sounds Great. Actually with such a trails, there is food and drink in the middle of the trip. That is for sure. This week we are planing new ride and to see how muddy will be. After snow in two weeks ago, now we have only rain! This was really great new powder snow, but as he come just disappear in few days :(
Thanks Franco and Thanks to all Subscriber for the support !!!
Edited by Asen_77
12 hours ago, Frank Angerano said:
My kinda trails!
Great video....
Thanks Frank. This are really great trails to ride :)
11 hours ago, quadnut20 said:
Thats a trail made for that raptor Id would have passed that 4x4 LOL Great  vid  !! Ive been following u on youtube also !!
Thanks for the support. Idea of the video was to ride behind him, other way this is Sportsman 500 so no problem to be passed ;)
    • By Need-help-with-quads
      Can anyone help me?
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By oxidized_black
    • By HSTAR
    • By ResQ91
      Hi guys
      battery and connections good
