Join Today, It's Simple and FREE!
Similar Topics
By technofarmer
Hi there i was needing to ask a question. I may soon be getting a UTV of one sort or another and not sure what is good or better to avoid? So far i hear great things about the Arctic Cat Prowler and Havoc, and many speak well of the Kawasaki Mule all but the 610?
So what are your thoughts and especially experiences? What have you had and used in farm life and trail riding that has held up well or hasn't?
By Mike Johnson
Does anyone know what the 3rd item is behind the battery on this ATV ? I know 1 is the, solenoid1 is the CDI box, what is the 3rd.
By Daniel Gibson
Working on a bayou 220 that has been ran extremely hard it's whole life. Literally had almost an inch thick dirt/oil covering the motor. Yeah that bad. Surprisingly it runs though. I cleaned the carb and tank multiple times. They're clean enough to eat off of. Readjusted valve lash and set timing. Was about 3 teeth off. It cranks good and runs good only problem is I have to cover the carb intake basically choking the hell out of it for it to start. The com choke works fine. It does this each time I start it regardless of temperature both ambient or motor. Wth? Compression is at 115psi I get 130s if I put a little oil in the piston chamber. Please help. Thanks
By JC4x4
My Honda Fourtrax won't start. The starter is kicking the engine over, but it won't start. It sat for about a year while I was living away, so I thought it might have been bad gas. I completely drained the fuel, flushed the fuel lines and filled it with fresh gas. However, still nothing. It started and ran fine the last time I used it. Any suggestions on how to diagnose this? It could be fuel or electrical at this point. Is there an easy way to rule one or the other out? Thanks
By Quadrunner44
I have an older 1980s Suzuki quadrunner red lt 4wd (250)
so just finished putting it all back together and was running fine just needed to adjust the rebuilt carb
bf decides to hook up an air chuck to the gas tank because it got a shot of air in the gas line well 120psi didn’t agree with any of the parts including the new carb
end result : new battery new carb now it just clicks (one single click) won’t turn over
hard to pull start gets hung up (unless I remove the spark plug ) gas flooded out the first time but now does nothing purchases a new starter waiting the arrival
could there be damage to the crank shaft or pistons etc? Or install the new starter and try to fire it up ? What caused the starter to die after he flooded everything with gas was working fine.
Thank you
