Hello I am new to this forum and lt80s I have an 87 that has burned up 3 coil/cdi combos my question is can I out the newer set up on it and if so how do I do it I know they have different number of wires going to the cdi mine only has 2 please help
  • Ajmboy changed the title to 1987 Suzuki LT80 Electrical Upgrade
Hope I'm not being a nuisance here booting all these old threads Ajmboy.. but I see there have been a lot of people looking. I presume someone will have the same problems.
Hope it's not breaking the rules posting links too.. let me know if I am. I'd contribute manuals directly but my internet is slow..
And as for the original problem of frying three sets of ignition coils and cdi units..  Cdi systems have to have a special sort of ignition coil made for a high current. If you put an after market coil on there that's not made for the cdi that would blow, and probably wreck the cdi unit.
Other than that, a bad earth somewhere, could be between the stator and the crankcase(unlikely unless it's a broken wire inside there), or the engine might not be properly earthed(also unlikely if the starter works), or the coil, or the cdi unit might not be earthed. ..
@Mech thanks for assisting, and no issues replying to old threads. We keep them mostly open. We do have the manual in our downloads section. I have removed your link and added the direct link to the manual. If you want to share manuals, please add them to our downloads section rather than direct links here: https://www.quadcrazy.com/files/
This way we can continue the library of resources in one place for the community. Thanks!
Good thanks for the reply.. I'm on a slow internet connection here and have trouble sending files..  If I could I would add manuals.. sorry. Thought I should ask about the policy. Some forums don't like links.. security or something I guess.
To the OP on this old link...and thanks for bringing it back @Mech, it's always good to think through old problems again....I would bet it's the regulator.  Too much voltage and the CDI is usually the first thing to take a dump.
    • By Dutchaaron
    • By captnunu
    • By toe420
      New member from BC. Anyone else from western canada?
