I have a Yamaha Big Bear 350 and the reverse doesn’t work, it shifts from low to high easily but it won’t go back to reverse. I’m new to this stuff, so I’ll take any help. Any ideas?
Edited by YamahaBB350
Mistake
Wow great point @Ajmboy i remember this topic! Could very well be just that !
I think it was the brake cable  adjustment or the linkage.  One or the other, we had another member that made adjustments and was no longer to get in reverse and he put it back where it was and it was fine. Maybe @Arizona
On mine I had to loosen up the foot pedal adjustment, I guess it needed to move more.
I adjusted my rear brakes and that's what caused the problem, after loosening them up
it worked again, Also had to be in 1st in order to go into reverse. Seemed to be a problem
an each Yamaha I have owned. Just got rid of one and same issues.
Don’t think I can help on this one. Mine was a 03 and automatic. However on that one you had to depress the foot brake to shift to reverse. There was a locking pin on the foot brake linkage. I deleted that to bypass the brake/reverse thing.
    • By Thumpinhard25
    • By fwsamm
