Its in pretty rough shape and its gonna be my first atv, I worked on bikes before but nothing to do with quads. Anyways the quad has some problems and im tryna figure out what to focus on first. So the U joints i think are shot. The bike starts first try every time ussually have to give it a lil gas with the throttle and revs right up, idles fine but its running REALLY rich 3 starts and my brand new plug was pitch black
Bike is L model
Its using the original mikuni carb but im not the best at fixing the carbs and wondering if there is anywhere online that would be able to either walk me through it or help me with it i didnt see a air mixture screw so it seems like im gonna half to open it up and adjust like the float and a couple other things
Edited by pablo Blake
You know the drill re: youtube and carb rebuilds.  you might take a look at that the post i have on here ("1999 Suzuki king quad fuel pump/petcock/carb advice") - it's pretty detailed and these guys helped tremendously.  I had some really good advice on the float in that post.  there are separate carb breakdown/cleaning topics on here, too.
look on this site for a service manual for your toy - if not available here, look on ebay - I picked one up (PDF) off ebay for around 6 bucks.
at least the beast is running, man!  that's a HUGE head start
i'll be following your post and seeing what the experts have to offer
Nice project bike to start off with. If she starts up straight away then half the battle is over ! But before you start to tear the carburetor off double check its not something as simple as the choke being stuck.  If its a black plug and a little black smoke coming from the exhaust then  it could be a stuck or broken choke cable or at the carburetor where the choke device is.
If not then yes you have to go deeper into the carburetor.
As far as U joints go its not a crazy big deal on most atvs.
The thing is the guy welded these u joints into place so im kinda stuck for how to get them off, And yeah the choke and throttle cable boot is completely disentegrated so it might be those it self, i can quite litterally rev the bike by pulling on the throttle cable near the carb same with bogging it down with the choke, Im contemplating sanding them out with a dremel and than knocking them out and making it flush again than reinstall new greaseable ujoints but idk the half shaft it self is quite old too, Would i be better going off with a new one. Im suspecting as he welded it might have heated it up and warped the knuckle whats creating a lot of the play
Im good with grabbing new cables but the thing is i didnt notice any spring action when playing with them feels like they just drop or up, I think i might be missing a spring in the carb, i just realized, Know if the cable it self will come with that spring
Welded the U joints?? Ugh some people!! Post a few pics i have to see this.
As far as the choke goes; locate the choke at the carburetor and get familiar with how it works, then after the bike is warmed up and running you have to verify that it's releasing and turning off allowing the proper amount of air flow into the engine.  There are a few different types of chokes so I'm not sure what is on yours.  Don't be shy and never be afraid to ask questions. Post a ton of pics and we will help you along wherever you need it.    Looks like you have a nice little place to work on the bike there too!
The cable will not come with the spring. The sprig actuation happens atv the carburetor so it could be as simple as that for the throttle and choke.
I'll post some pics after this last christmas party today than i can dedicate some more time to it. All i really know is i've never worked on one like it. Only screw i can find to adjust anything externally on this mikuni is the idle/pilot screw
Ok well its not rocket science and I'm sure your more then capable to do this based on what i've seen from the pics and the way you are posting so you got this!
But def going to need some undisturbed time so do what you have to do and when your ready to tackle it have a clean work area, piece of cardboard and a sharpie to write  on as well as a separate piece to be able to stick bolts and screws in to properly label and keep track of where they came from.
U joints all though i haven't seen a pic yet but im assuming the welds will be hard to grind so if thats the case get familiar with a pencil grinder! Best tool on the planet for getting rid of welds in tight places.
 I downloaded a good manual from this site for my 1989 lt f250. I've gotten lots of help from this site also so good luck with your new venture.
Yeah i just grabbed the manual and giving it a once over well i match sh** up, I was looking for the oil filter location but as far as i can tell it doesnt have one. Finished the party and emptied the oil, Smelt like solid gas and was BROWN black. gonna have to give it a good flush, Is that gas most likely from it running so rich? or is it some kind of gasket leak to the crank case
Attached some pics of the carb that im working with, Before i even get it out want to see what i have to do and than get it done. any tips for getting the exterior cleaned up also? want to get bike back to looking brand new
Looks pretty straight forward. The cables look a little bent over more then usual.  Once you pull the carburetor off your going to need two cans of carburetor cleaner spray. I use gum out.  Spray the outside down and let it sit for a little bit and then wipe it down good. You can use Q Tips to get in small spots and loosen dirt.  I like to put the carburetor in a frisbee or a low tupperwear container to work on.   Definitely going to have to look into the cable connection points to see whats happening there.
Is it me or does it look a little burnt in the area of the carburetor? No evidence of a fire at all ? It just looks a little dark.
I looked and checked everything doesnt seem to be any evidence of a fire Wiring harness is decent and the plastic and seat are all intact so i mean it looks fine, Im guessing some idiot sprayed carb clean on it and accidentally lit it on fire. Never know what the previous owners couldve done to it. The throttle cable i can quite literally Pull right out of the carb and the only thing connecting it is the cable which it revs to all sh** when i do it, im scared to even take it on a trail before i figure this out because it seems like if i hit a nasty bump the throttle is gonna jump, ussually i'll give a machine a feel ride before taking it apart when i first get it. So i can feel whats wrong with it. deeper into the bike but this i was scared to even kick on outta neutral unless i had full control of the bike
Good move on not taking it out yet. Anything else you can deal with, a run away throttle not so easy.    Get that right and go from there.   That throttle connection screws into the carburetor so check its not broken in the carburetor.
Some of the third party manuals say the pilot screw is 1 7/8 turns out, my 93 LT-4WD ran way too lean and would puke it's guts out.  I scored a factory manual off ebay for it, and it states 2 full turns on the pilot screw.  Pulled the carb again and set to 2 turns which did the trick.  Would also be worth double checking the needle and seat aren't sticking wide open.
Yeah the factory manual i have doesnt say anything about the turns, Im gonna pull it off tonight and give it a good clean and look. Also the air box has some oil like stuff in it good way to clean it out when getting it off? Can i use like brake cleaner or something like that or should i use carb cleaner since its ment to be used on something that fuel is gonna go through.
Ended up picking up a fram ch6066 today gonna install it after i give everything a good clean and give the float a check
"I hear ya and agree, the best part about this type of situation is all the members that go through this get very good at pulling the carburetor off so making several adjustments gets less difficult."  He's got that right - "Frank" was not the name I'd given him when he recommended that I remove my king quad carb AGAIN to make adjustments - but it was worth it - he's a great teacher - and you do become somewhat of an expert at putting it back on (and taking it out, and putting it back on, and taking it out....).
here are some tools I used to help:
old long allen head wrench (used to put furniture together) - grinded off end to width of air/fuel screw under carb:  it's long enough to access from the side
"ol' red" - rounded/sanded an old slot head screwdriver: comes in handy when inserting TIGHT ARSE rubber boot between air box and carb - this gave me fits to no end - a bit of grease on inner lining helps, too
old open end 12mm wrench for throttle cable - thinned it out w/ grinder: helps with final tightening of throttle cable to carb - this was difficult to get started but eventually seats
  • Thanks 1
Definitely gonna try that next thing im looking for is a bolt sizing chart for the atv or something along those lines cause a lot of bolts are missing. Gonna try and clean out the air filter it looks old and clogged as sh** i read that i can clean it instead of replacing should i clean or replace with a k&n
Will do im looking at a uni competition airfilter , Now im kinda stuck because the bike is missing a bunch of bolts and some broke. Been trying to find either a whole new set or a place with the sizes of the nuts and bolts and screws on the diagram
Good idea on the air filter and the brand is good.
Heres a set of nuts and bolts I have used in the past. Its been great since i have used it over many projects but its $98.00. Mine has paid for itself already but there are smaller sets available.
Metric Class 8.8 Hex Cap Flange Frame Bolts & Flange Nuts Assortment Kit - 429 Pieces! https://www.amazon.com/dp/B01LYF0OHX/ref=cm_sw_r_cp_api_i_AQDdEb7RZ6D8D
I'm gonna go to the local hardware store and see if they have any that match up to this pitch and diameter in the same length for cheaper and just the ones i need https://specbolt.com/technical-faq/
I was looking everywhere for those numbers and specbolt just throws em at you
Quote
Common metric thread pitch for motorcycle and ATV uses are M4-.7, M5-.8, M6-1.0, M8-1.25, M10-1.5, M12-1.75, M14-2.0 and M16-2.0
if not theres a couple places local that make bolts that i can probably order a shipment of the ones i need from, I just dont feel like using my tap and die set on every goddamn screw/bolt to resize it to commonly available threads
    • By oxidized_black
      1981 - 2008 ATV HISTORY
      1986 - 2006 Kawasaki KLF300 Bayou service manual
      1988 - 2002 Kawasaki Bayou 220 service manual
      1994 Kawasaki Bayou 220 Owner's Manual
      1997 - 2002 Kawasaki Prairie 400 service manual
      2003 - 2005 Kawasaki KLF250 Bayou service manual
      2003 Kawasaki KVF360 Prairie service manual
      2004 Kawasaki KFX700 V Force service manual
      2004 Kawasaki KVF700 service manual
      2005 Kawasaki KVF750 Brute Force service manual
      2006 Kawasaki KFX80 Specs
      2008 - 2009 Kawasaki KVF750 Parts Manual
      2008 Kawasaki KFX450R service manual
      2008 Kawasaki KVF750 Brute Force service manual
      Please visit the downloads section at https://www.quadcrazy.com/files/
      CARFAX https://www.carfax.com
    • By Ethan7387
    • By GatorHunter
      Thank you, and enjoy
      GH
      1985 Scrambler
      1985 Trail Boss
      1986 Scrambler
      1986 Trail Boss
      1987 Trail Boss
      1987 Trail Boss 4X4
      1987 Cyclone
      1988 Trail Boss 2X4
      1988 Trail Boss 4X4
      1988 Trail Boss 250 R/ES
      1989 Trail Boss
      1989 Trail Boss 2X4
      1989 Trail Boss 4X4
      1989 Big Boss 4X6
      1990 Trail Blazer
      1990 Trail Boss 250
      1990 Trail Boss 2X4
      1990 Trail Boss 2X4 350L
      1990 Trail Boss 4X4
      1990 Trail Boss 4X4 350L
      1990 Big Boss 4X6
      1991 Trail Blazer
      1991 Trail Boss 250
      1991 Trail Boss 2X4
      1991 Trail Boss 2X4 350L
      1991 Trail Boss 4X4
      1991 Trail Boss 4X4 350L
      1991 Big Boss 4X6
      1991 Big Boss 6X6
      1992 Trail Blazer
      1992 Trail Boss 250
      1992 Trail Boss 2X4
      1992 Trail Boss 2X4 350L
      1992 Trail Boss 4X4
      1992 Trail Boss 4X4 350L
      1992 Big Boss 4X6
      1992 Big Boss 6X6
      1993 250 2X4
      1993 350 2X4
      1993 250 4X4
      1993 350 4X4
      1993 250 6X6
      1993 350 6X6
      1993 Trail Boss
      1993 Trail Blazer
      1993 Sportsman
      1994 300 2X4
      1994 400 2X4
      1994 300 4X4
      1994 400 4X4
      1994 300 6X6
      1994 400 6X6
      1994 Trail Boss 2W
      1994 Trail Blazer 2W
      1994 Sportsman 4X4
      1994 Sport
      1995 300 2X4
      1995 400 2X4
      1995 300 4X4
      1995 400 6X6
      1995 Trail Boss
      1995 Trail Blazer
      1995 Sportsman 4X4
      1995 Sport
      1995 Xplorer 4X4
      1995 Scrambler
      1995 Magnum 2x4
      1995 Madnum 4X4
      1996 Trail Blazer
      1996 Trail Boss
      1996 Xplorer 300
      1996 Xpress 300
      1996 Xplorer 400
      1996 Xpress 400
      1996 Sport
      1996 Scrambler 4X4
      1996 Sportsman 4X4
      1996 Sportsman 500
      1996 400 6X6
      1996 Magnum 2X4
      1996 Magnum 4X4
      1996 Magnum 6X6
      1997 Trail Blazer
      1997 Trail Boss
      1997 Xplorer 300
      1997 Xpress 300
      1997 Xplorer 400
      1997 Xpress 400
      1997 Xplorer 500
      1997 Sport 400
      1997 Scrambler 4X4
      1997 Scrambler 500
      1997 Sportsman 4X4
      1997 Sportsman 500
      1997 400 6X6
      1997 Magnum 2X4
      1997 Magnum 4X4
      1997 Magnum 6X6
      1998 Trail Blazer
      1998 Trail Boss
      1998 Xplorer 300
      1998 Xpress 300
      1998 Sport 400
      1998 Scrambler 400
      1998 Scrambler 500
      1998 Xplorer 400
      1998 Magnum 2X4
      1998 Magnum 4X4
      1998 Sportsman 500
      1998 Big Boss 500 6X6
      1996 Sportsman 400
      1996 Sportsman 500
      1996 Xplorer 500 4X4
      1997 Sportsman 400
      1997 Sportsman 500
      1997 Xplorer 500 4X4
      1998 Sportsman 400
      1998 Sportsman 500
      1998 Xplorer 500 4X4
      1999 Sportsman 400
      1999 Sportsman 500
      1999 Xplorer 500 4X4
      2000 Sportsman 400
      2000 Sportsman 500
      2000 Xplorer 500 4X4
      2001 Sportsman 400
      2001 Sportsman 500
      2001 Xplorer 500 4X4
      2002 Sportsman 400
      2002 Sportsman 500
      2002 Xplorer 500 4X4
      2003 Sportsman 400
      2003 Sportsman 500
      2003 Xplorer 500 4X4
      A01CH50AD
      A01CH50AA
      A01CH50AB
      A01CH50AE
      A01CH50AK
      A01CH50AF
      A01CH50AJ
      A01CH50EB
      A02CL50AA
      A02CL50DA
      A02CH50AA
      A02CH50AB
      A02CH50AE
      A02CH50AK
      A02CH50AC
      A02CH50AD
      A02CH50AJ
      A02CH50AL
      A02CH50AM
      A02CH50AN
      A02CH50FA
      A02CH50AAEB
      A02CH68AA
      A02CH68AB
      A02CH68AC
      A02CH68CA
      A02CH68CB
      A03CL50AA
      A03CH42AA
      A03CH42AB
      A03CH42AC
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03CH50AA
      A03GJ50AA
      A03GJ50AB
      A04CL50AA
      A04CH42AA
      A04CH42AE
      A04CH42AG
      A04CH42AQ
      A04CH42AT
      A04CH42AV
      A04CH42AS
      A04CH42AR
      A04CH50AA
      A04CH50AC
      A04CH50AE
      A04CH50AG
      A04CH50AO
      A04CH50AQ
      A04CH50AR
      A04CH50AS
      A04CH50AT
      A04CH50AV
      A04CH50AW
      A04CH59AF
      A04CH59AH
      A04CH59AJ
      A04CH59AT
      A04CH59AV
      A04CH59AK
      A04CH59AL
      A04CH59AN
      A04CH59AW
      A04CH68AC
      A04CH68AF
      A04CH68AH
      A04CH68AJ
      A04CH68AT
      A04CH68AV
      A04CH68AK
      A04CH68AL
      A04CH68AN
      A04CH68AO
      A04CH68MB
      2004 Ranger 2X4 Parts Manual
      A04RB42AA
      2004 Ranger 4X4 Parts Manual
      A04RD50AA
      2004 Ranger 6X6 Parts Manual
      A04RF50AA
      A05CL50AA
      A05MH42AB
      A05MH42AG
      A05MH42AH
      A05MH50AB
      A05MH50AC
      A05MH50AG
      A05MH50AH
      A05MH50FB
      A05MH59AK
      A05MH59AN
      A05MH68AK
      A05MH68AN
      A05MH68AC
      A05MH68AS
      A05MH68AU
      A05MH68AW
      A05MH76AC
      A05MH76AU
      A05MH76AW
      A05MH68AP
      A07MH68MA
      R07RF68AD
      R07RF68AF
      R08RF68AD
      R08RF68AF
      2009 Outlaw 90 service manual
      Other Stuff
      Download Manuals HERE
      Some ATV manuals available in the downloads section at https://www.quadcrazy.com/files/
      Find them on on:
