Yamaha Bear Tracker 250 Where to start?
payne
@Gina Owings welcome to Quadcrazy.
Sounds like a nice deal for $200 bucks.
Im sure we can help you out with this.  There are a few artic cat people here that know there stuff.
But first off go to the home page and start a new topic on this so its easy to track.
Post a few pics and whats going on and we will see what we can make of it!
So, I hit the bezel with clear after I outlined the lettering with a silver sharpie. It turned out ok. I thought a d thought about it and decided to paint the plastics because they are so faded that I thought the clear wouldn't do the trick. I'll post more when I'm done.
This was the paint job i did in my first bear tracker.  My plastics were way beyond repair with cracks etc.  Its when i first got back into the whole atv thing.
I was really in need of a hunting atv as well so i went with a  camo pattern.  I also took it upon myself to buy fabric and learn to cover my seats.
I always find myself looking back at my old photos on some of my projects i did. Some were cool, some were so so but i was not good at refinishing the plastics until later.
As soon as this Suzuki of mine is done i will get back into my side project on a really beat up and old piece of plastic that i picked up from an old bayou. Its just a test piece and im hell bent on bringing back the shine.  Im close to a process that will require no paint or clear coat.
So I installed new relay and new solenoid and now starter is cranking again. Damn it!
I didn't have time to trouble shoot tonight but maybe tomorrow night.
Gonna have to go back and look thru the posts again.
Relay does not click and I even put the old one back in and nothing. All lights work though.
    • By Brantley11
      Hey everybody,
      Here is where we sit:
      New 93 Non Ethanol Gas
      New Spark Plug
      Bluish white spark
      Good Compression
      Here are the readings:
    • By 86ccord
    • By Mhatayas
    • By STLJ
      Gday all,
      Been trying a couple different ways now to download a manual. Not sure what I am doing wrong but could someone walk me thru it?
      I go to DL page and click on link
      get a pop up for a PDfixer or something
      close that and then hit download button and no go
      tells me I have reached my limit but I have never DL anything ever.
    • By justent_88
